cant find 12v dc-dc plans :(
  • cant find 12v dc-dc plans :(
    im after 12v dc-dc plans
    so when the engine cranks i still get 12v
    i know there is a few plans on here but i couldnt find anything when i searched..
    anyone??
    thanks
    View My Blog
    Click for 2GB FREE on-line storage!
    Which planet you searching on ...?
    Mastero
      u can search on other planets? i'll be
      View My Blog
        You might want to check out Mastero's sig
          there full psu's.
          i just want 12v out, unless i missed it on his site?
          btw : neat seat up mastero
          View My Blog
            Arenīt you refering to a tank circuit ?? as far as i know, the only way to get a stable 12v in a car when cranking it's with a tank circuit.
            Brave
            Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
            Status -->
            Lilliput Installed (not indash yet..)
            BraveCar 2.5
              My friend get creative .. use only the 12 v section ...
              MAstero
                there full psu's.
                Why would you need anything then If your input is 12v and you want an output of 12v, I would connect whatever you have directly to the input voltage
                get it
                On a more serious note try Radio Shack or some electronic store if you just need to keep the voltage stabilised.
                2002 Chevrolet Avalanche
                Gigabyte Z97 mITX Intel Mobo, 8GB RAM, Intel Core i5-4590S 3.0GHz Proc, 320 GB Hard Drive, Dual 12' VGA HDMI DVI touchscreen monitors,....
                http://www.mp3car.com/show-off-your-...avalanche.html
                  http://www.carnetix.com/GoodHumor/good_humor.htm
                  Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
                  Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
                  CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
                  http://www.no1knows.com/galleries/
                    If you want a low 3A max 12.6v one based on Mastero's design, there's a lilliput regulator by shchua. The important thing I've learned from this design is that the voltage must drop some between input and output, so at 13.x in you can get 12.0 out, but at some specific voltage it will break down and drop considerably, so you need two sections. One that steps up to volts to say 20+, then the other regulates it down to 12. That's how you keep 12 in or even lower during crank at 12 out. Just a simple regulator can't do that.
                      Originally posted by no1knows
                      I'd laugh more but it's somewhat true
                        get it
                        i need 12v even when the engine is cranking.. so i need something that will make 14-8 into 12v..
                        View My Blog
                          http://www.mp3car.com/vbulletin/show...ghlight=pt5071
                            thankyou
                            thats the one i was after
                            View My Blog
