12V to 9V/5V
  • 12V to 9V/5V
    What do you use to regulate current from 12V(car battery...) to 9V and 5V??
    I need 5V for a USB hub and 9V for a VGA dublicator!!!!
    5v from PC, nine volts from this http://www.radioshack.com/product.as...Fid=273%2D1863
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
      Or This http://www.radioshack.com/product.as...Fid=270%2D1535
      to this http://www.radioshack.com/product.as...Fid=273%2D1857
      and this http://www.radioshack.com/product.as...Fid=273%2D1863
      2 Kicker Comp 10"
      Check it out?!
        or you could get daring and try some 7809's for your nine volts and 7805's for the five volts DC
          I don't want to use 5V from my Opus because I don't know if it can handle it!!!
          Those from radioshack are good enough but only 1A
          Thank you!!!!!
            A USB hub could use up to 2.2Amps.... How can I solve this problem by using the above adaptors or something else??
              If you can open the hub and do a little hacking, I guess you could cut off the +V from the output ports and connect one 7805 to each port!
