NEW Small DC-DC Power Supply
  • NEW Small DC-DC Power Supply
    I have see lot of request for power supply to give 10 to 14 volt
    If you can make electronic you can use this simple schematic
    It got because you connect to you car battery directed, It not make lot of heat
    The some of the part I get as free sample
    Other part I get from old pc power supply
    This power supply will cost my max. 5$ and 1-2 hours work
    I think small cost is good
    Plan for project = 100%
    Part the project. = 100%
    Built...................= 99%
    Finish.................= 99%
    Install ...............= 99% -50%
    Ditail at 4u2n.dk
    Here
    can it be modified to give out a constant 12v?
    View My Blog
    Click for 2GB FREE on-line storage!
      Put a jumper over the multiture resistor and change R3 to 218 Kohm 1%
      the et give +12 volt out
      Ditail at 4u2n.dk
      Here
        Diagram for 10 power supply with can be use in a mp3car project
        info on my homepage
        Ditail at 4u2n.dk
        Here
          Where T1 you have found the transformer and name to the Mosfet N1 its?
          Hi
          Mauri
            Hi
            Mauri
            ??? I think is ok
            Ditail at 4u2n.dk
            Here
              will you make these and sell them for those of of that aren't electronic literate?
              mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
              Total = $746....Carputer = Priceless
                Not now, i have to finish my project
                I'll think there can be a chance to some when I finish my Mp3Car
                Ditail at 4u2n.dk
                Here
                  The transformer T1 and' difficult to find..
                  Do you know a place where to purchase it on-line in Internet?
                  Mauri
                    let us know how good and efficient this device is once you have your carputer all setup...
                    i'd be interested in checking it out, since looking at tat electrical diagram doesn't mean anything more to me than egyptian heiroglyphics
                    nine.
                      Mauri
                      The transformer T1 I get as free samples for Cooper Electronic Technologies
                      http://www.cooperet.com/
                      1 week to get et
                      Ditail at 4u2n.dk
                      Here
                        You won't power much computer with 2.5A, certainly not an EPIA...
                        GingerPrince
                        Car changed for TVR Griffith 500, so computer de-installed. Using a Dension 100ix w/60Gb HD unit in the interim.
                        Carputer Install - http://www.stuffandting.com/carputer/
                        CarBox Software -- http://www.stuffandting.com/carbox/
                          No you are right, I post this diagram because many ask for small power supply
                          witgh small change it give 5 Amp
                          The system I run at home plan to put i the car I power by a small switch power there giv 4.16 Amp
                          Ditail at 4u2n.dk
                          Here
                            You can run a small Network fileserver base on EPIA 800 with 2.5" harddisk
                            19.23 Watt
                            Epia Power simulator
                            Ditail at 4u2n.dk
                            Here
                              OMG, R5 should never be 0, that would possibly POW the IC with the inrush to the gate capacitance, it should be closer to 10 ohms.
                              Carputer currently 'ghettoed' into car!!!
                              EPIA MII-12000
                              Ampie Case with rigged extra USB
                              Hitachi 60GB
                              Holux GPS mouse with iGuidance 2.0
                              Lilliput 7" touchscreen
                              Netgear WG121 USB WiFi
                              Carnetix P1260
