What size PSU do I need
  • What size PSU do I need
    Probably asked a thousand times... But there's the 1001th
    - Via Epia MII 12000 or M10000 depending if I use my pcmcia wifi and cf cardreader for digicam
    - 512MB single DIMM 266MHz
    - W.D. 200GB 7200rpm 8MB buffer HDD (probably a big power draw)
    - Panasonic slot CD-RW/DVD
    - WiFi either my pcmcia card (will probably work only in my garage) or a USB device with antenna (better reception)
    - Royaltek Sapphire GPS (USB)
    - Lilliput screen (USB for touch screen but own power)
    - Wireless keyboard - Not choosen yet (USB probably)
    I might eventually get a good sound card in order to send separate RCA feeds to front, rear and subs amps (5 channels), so I need to consider having power for that card if needed. Or maybe I can send the digital output from the via SPDIF to a module that will separate all signals to send to the amps.
    Also, I read here that the resolution is not widescreen compatible on the epia so a pci video card might be wanted, I need to consider this also (not finished my reading on the subject yet, too much info on this forum;-)
    I think that's all I need powered.
    Will a Opus 90W be enough, do I need the 150W? What about the Audioforge 200W which sells for half the price (100$) of the Opus and has ITPS included?
    Etienne
    ok, audioforge, which is PW-200 crap.. I don'T want that
    so, 90W or 150W Opus?
    Etienne
      An OPUS 90 watt should be enough, but I can't garuntee it. If you have the possibility of putting the DVD drive on its own power supply if it is too much then I would get the 90 watt and take off the DVD if it won't boot, otherwise just spend the bit extra and get the 150.
      I'm running an AMD 2000+ with 7200 rpm hard drive, 3D card and a bunch of USB stuff and I'm drawing just a hair over 90 watts when I running at full processor usage.
      StreetDeck.com Developer (I am Chuck)
      Get StreetDeck at http://www.streetdeck.com
      The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
        Check out www.mini-box.com , and under the mini-box news menu, there's a power simulator button. Click it, and you'll find your answers.
        Renault Megane...the OEM look
          The OPUS 90 watt would work will with your setup. http://www.mp3car.com/store/product_...products_id=30
            Here is an awesome white paper to use
            Here is an awesome white paper that helps you work out how much power your board will consume.
            http://www.via.com.tw/en/VInternet/power.pdf
            It is written mobile 12v application and covers everything for shutdown contoller to hard drive power consumption.
