Correct me if I'm wrong about Opus 90W
  • Correct me if I'm wrong about Opus 90W
    I'm planning on ditching the inverter & AC P/S combo that I'm using now and switching over to an Opus. I'm under the impression that the Opus does not need an ITPS. I've had it with the PC not surviving the crank cycle and having to shutdown manually, not to mention that the inverter is too power hungry to hibernate the PC. Just want to make sure I get everything I need in one shot instead of having to place 2 separate orders.
    Opus PSUs don't need any voltage regulation when connected to a car battery.
      You are right. The OPUS 90 watt does everything all in one package. No need to buy anything else.
        Thanks fellas, the less money I have to spend the better.
