Call me stupid....Basic opus instalation questions
  • Call me stupid....Basic opus instalation questions
    Finally got all i need to install my incar PC
    I ordered and opus and it comes with no paperwork whatsoever and there website has only basic descriptions....
    Im sure i could guess and get it right, but i dont think its smart to take a chance of blowing up a $200 PS and $700 worth of computer when i could just ask.
    How do you wire it?
    -Red wire? Power? I search and found this obviously is wired to the battery with a 30a fuse
    -Yellow wire? is this the ignition wire? OR is this the power wire?
    -Black im pretty sure is ground, and i can figure where that goes
    Now it came with some jumpers, i assume these are to controll the shut down timer...where do they go?
    Anyother tips for installing this please feel free to add. or possibly a link to the setup instructions
    btw...i ed
    My 97 SS Website
    Red wire = power
    Yellow wire = Accessory (so it knows when your car is turned on/off.
    Black = Ground
    Jumper is for the shutdown controller. If you want to put that on you have to open up the power supply and there is a place to put the jumper. With the jumper off it will shut down after 10 seconds (default).
    Tip: if you have an Amp that is already wired to the battery, acc., ground, you can just tap into that.
    There is a manual in PDF format that you can get. Search the forums for it. I know several people have posted a link to it. I just don't have time to look right now. Good luck!
    Installed.
    -GPSSecure- - GPS Tracking
      The OPUS I have here has Red, Black and Blue input wires.
      Red = Power (Constant)
      Black = Ground
      Blue = Ignition (Switched Power)
      If they have change the blue to yellow, it should be the same.
      Email me and I will send you a PDF copy of the instructions.
      BTW is it a 90W or 150W OPUS?? Just to make sure I send the right copy.
      : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
      : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
      : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
        Black = Ground
        Thanks guys,
        its an opus 150w
        [email protected]
        THANKS!
        My 97 SS Website
          http://www.mp3car.com/vbulletin/show...identify+cable
          This should help you. It helped me
          Status: [|||||||||-] 90% finished
          My 2000 Chevy Monte Carlo SS Install
            http://www.mp3car.com/products/SFX_D...uide-Rev_C.pdf
            the manual is listed in the products section of this site
            Signature: [==||========] 20% complete
