Morex 80w PSU not working?????
  • Morex 80w PSU not working?????
    I'v just hooked up my morex 80w psu and it doesnt seem to work
    When i hit the power button on the motherboard i heer a noise WINE but nothing happens
    I hooked it up as the instructions says (instructions didnt say much)
    i have the 12v into the power supply by the lighter socket and then i have the ATX cable from the PSU to the motherboard.
    Im using a ITX MII 6000 with a 600mhz fanless cpu so its not draining to much it wont start.
    They only have a 60watt car psu on there website
    http://www.morex.com.tw/PDF/Installa...0Cigarrate.pdf
    That is what i got but the to power button wasnt on my sheet.
    Then there is this one about hooking it up to the battery
    http://www.morex.com.tw/PDF/Installation_Guide.pdf
    It mentions the 4 pins on the board which i gather pin 1 and 2 go to the motherboard and pin 3 and 4 go to a button to turn on the PSU which turns on the Motherboard.
    I had it hooked it and flicked the motherboard switch then i pressed the 2 contacts on the PSU that says switch to the front and it didnt do anything
    makes a WINE noise when i push power on the motherboard and i pushed both contacts on the board where it says switch front panel but still nothing
    Does anyone have any idea?
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    My only comment at the minute is that if I understand you correctly you are not using the power switch, you are simply shorting across the two pins. I believe this needs a certain restiance rather than just shorting!
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
      But a power switch from the PC is the same as shorting.
      I just modifyed a CD audio cable for the soundcard to connect from the PSU to the motherboard and i use the other 2 wires to start the psu and mb as shown in the second PDF and all i get is a WINE noise still
      Im still just shorting the to wires to start it but i get the wine but i short the pins from the PSU which makes the wine noise which only happened when i made the motherboard start up so it seems like the cable does make the motherboard switch go but it just wines nothing else
      [edit]
      On the DC hub a guy mentioned that the WINE noise could be that there isn't enough power through the lighter socket so i tryed it in another car and still the same so i dont know whats wrong maybe its a bad PSU ???
      [edit]
      CarPC Status:
      GPS: 99%
      Hardware: 99%
      Software: 92%
      Case Install: 99.9%
      Dash Install: 100%
      Car Install: 72%
