Opus power supplies ---> for AMD mobile???
  • Opus power supplies ---> for AMD mobile???
    Hi all,
    I'm a new member
    I'm trying to build a carputer using a microATX MB with
    a XP barton 2600+ mobile CPU. This system can be
    downclocked or overclocked it's depend on the power
    I have.
    But, The major problem I have is the power supply
    I found one power supply with 400 watt but it's cost 300€/280$
    so I'm looking for the opus solutions. My question is, can I use one opus
    power supply for an AMD CPU working at 25 watts at downclocked
    frequency and 50 watt at overclocked frequency?
    I see the Ampere of the power supplies and does not appear suitable!
    Please give me an indication/suggestions
    According to the Opus website the Opus 150 has 5a continuous on the +12v line...that's 60w. Does it use the 5v or 12v line?
      the cpu is working on 3.3v and have 10A so the maximum power is 33 watts.....
      not sufficient
        I am using a XP 2600 but I had to underclock it because my motherboard doesn't have a place to plug in the 12v line.
        Installed.
        -GPSSecure- - GPS Tracking
          Hi Brady
          what mean "does not have a place to plug"????
          I will use the soltek 75MIV2, so do you believe it's possiple to use the 150W
          with XP 2600 + mobile at normal frequency?
            I've used an Opus 150W with an Athlon-M 2600+ without difficulty.
              Very interesting.............
              your sign show XP 1600............ but
              did you try also a mobile 2600 + with that carputer?
                not sufficient
                I dont think that is true, my xp mobile cpu uses the 12v of my psu (of my normal computer).
                3.3v is not being used for cpu's, some motherboards use the 5v, some the 12v, the 3.3v isn't powerfull enough for cpu's like amd mobiles.
                For the opus a simpele solution:
                underclock it. Normally the 2600+ works on 1.933ghz with 1.45v. Lower the mulitplier and the voltage. Maybe 1.0ghz with 1.2v works stable, and if so: that wouldn't use much ampère (and watts)
                If 1.0ghz would not be enough, then raise the multiplier, and the voltage a bit.
                Newbee, sorry for my bad english. lol
                Trying to built a carmp3 systeem
                own psu: max788, pt5071, pt5024
                  See, that's what I thought too...but I figured I could be wrong
                    Hi Brady
                    I looked up your motherboard specs and it looks like it has a 12v input. You should be able to run your CPU at full speed with the Opus.
                    Installed.
                      because of 12V input?........
                      that it's fine
                        ok i had emailed opus on something like this here what i wrote and what they responded to me.
                        > hi i bought a opus a few months ago and at that time i
                        > have a epia m9000. well i am constructing a new system
                        > and i am going to put in a few things and wanted to
                        > know if i would have any problem with it.
                        > 1 ASUS A7N8X-E DELUXE
                        > 1 AMD Athlon XP Mobile 2600+ CPU
                        > 1 slim drive dvd/cd ide
                        > 1 usb bluetooth dongle
                        > 1 ATI RADEON 9600
                        > 1 7" touch screen (not running off opus but it has a
                        > usb connector)
                        > 1 usb gps
                        > 1 tv/radio pci card
                        > 1 keyboard
                        > 1 2.5 40gb hd
                        > 1 2.5 20gb hd ( this one will not be pluged in al the
                        > time)
                        > so i just want to know if the opus 150w can handle all
                        > that?
                        > thanks sam b.
                        I dont see a problem all except the ATI Radeon 9600. Do you know how
                        much
                        power does the ATI consume on +5V and or +3.3V ?
                        Kris
                        i gave him the specs and thats what he told me. i have still waiting on my agp card, but when that gets here i will find out if it works i end up using a different one. seeing that the ati car was a +5v and did not want to run the rist of not having enough power. hth
                        Best Technique In Life Is Having No Technique
                        ONE DAY I WILL LEARN HOW TO USE THE COMPUTER THE RIGHT WAY.
                          I run a Xp Mobile fine with an Opus
                          CarPC status: iPod, 3,456,217 songs so **** you
                            Update us on the ATI 9600. I am planning to run the AIW 9600XT and wonder if OPUS can power it.
                            Honda Lagreat Carputer Project. Mobile Entertainment
                            http://www.mp3car.com/vbulletin/showthread.php?t=33936
                            Full Spec for mods check out:
                            http://www.hondashowoff.com/profile.php?id=3766
                              I know for the 9600pro and the XT, not for the normal 9600
                              9600pro:
                              Idle:
                              3.3v: 0.95A
                              5v: 0.16A
                              12v: 0.4A
                              Total: 8.69W
                              stressed:
                              3.3v: 2.92A
                              5v: 0.46A
                              12v: 0.57A
                              Total: 18.38W
                              9600XT:
                              Idle:
                              3.3v: 0.74A
                              5v: 0.47A
                              12v: 0.35A
                              Total: 9.07W
                              stressed:
                              3.3v: 3.2A
                              5v: 0.99A
                              12v: 0.63A
                              Total:22.72W
