carnetix cnx-p1260
  • carnetix cnx-p1260
    ive done some searching on this ps but cant find the info im after..
    ive decided to spend more money than i have and dinch the laptop cus its a waste of time and get what i should have got from the start, a mini itx
    ive noticed u can get the TC boards with onboard 12v dc-dc for not much more than a normal board..
    http://www.viavpsd.com/product/epia_...herboardId=201
    to use one of these all i need is the carnetix cnx-p1260? yes?
    http://www.carnetix.com/CNXP1260.html
    and this will work the same as opus? on a boards without dc-dc converter?
    last question which i couldnt find answers too.
    ive got a laptop HDD going to the itx.. these use 5v's and the
    p1260 doesnt have a 5v out put, or does the ME itx boards have 5v outputs to run a 3.5" HDD??
    thanks
    Mick
    View My Blog
    Click for 2GB FREE on-line storage!
    i'm not quite sure what you mean in the last bit, but the TC mobo has a plug to connect and power the hdd from the onboard 12v dc-dc
    Signature: [==||========] 20% complete
      The CNX-P1260 will work perfectly with the Epia TC boards.
      The 12V power supply on the TC board provides all the voltages you need for a computer. The CNX-P1260 provides a clean 12V into the TC, which requires 12V +/- 5% (which you can't get from a car normally!)
      The CNX-P1260 will also sort out starting up and shutting down
      Garry
      Co-Developer of A.I.M.E.E
      www.aimee.cc
        yeah thats what i thought... do normal size HDD use 5 or 12v?
        anyone know how much they are also.. the web site doesnt say?
        i wana do some price comparisions with it and the opus 90w
        View My Blog
          i think they use both, they were about US$85 i think but they arent selling them for the moment because they are out of stock, a CNX-P1260 and TC mobo is much cheaper than an opus an a m10000, but i dont think i'd have enough power to power all my stuff, i probably need 80w not 60w
            i think they use both(
            that was my main concern, the opus has 2 12v and 1 5v out and the TC board seems to only have a 12v ouy going by whats on the via site.
            is the p1280 out yet? the site says it isnt..
            what are u running on urs for 60w not to be enuf?
            View My Blog
              normal desktop HDDs use 12v and 5v the laptop HDDs only use 5v
              2-15" ILO lcd w/DVI
              6800 gt Duel DVI out
              p4 1.6ghz flex atx board
              1gb 400 ram
              120gb(2-60gb raid) sata hd
              2-60gb hotswap
              WIN2K Pro SP2
              M.A.M.E. w/2,300 games
              CARPuter info
                ok thats good.. they u can just get one of them ide->2.5" converters and bobs ur uncle
                View My Blog
                  full size hdd, extigy and lilliput
                  no the 1280 isnt out yet
                    I've run a full-size, 7200rpm hard drive from the CNX-P1260, plus a Xenarc screen (the Lilliput uses almost the same power)
                    Do the Lilliput egg conversion and you can power your Extigy too
                    Garry
                    www.aimee.cc
                      extigy is 12v not 5v
                        If you read the forums at carnetix.com you will see that mikeh is comeing out with a better version of the cnx-p1260
                          i couldnt find any info on it at the forum... u know whats gonna be changed?
                          View My Blog
                            Yes , please share where you got this information. I can't find it on their forums.
