Universal Microelectronics DC-DC convertor
  • Universal Microelectronics DC-DC convertor
    Anyone use their DC-DC convertor before?
    http://www.umec-web.com
    pick up a piece of UM2701. rated in 9v-18v, out 5V 3A.
    tested it out just now, pretty good. fed it 13.8v and spit out 5v exact.
    only thing is the rated efficiency is 78%
    Am thinking of using it to power some 5V devices in the trunk, any issues?
    kao
    CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
    wonder how cheap it is, or if they give samples?
    Previous: CamryAmp 1.0 - 95 Camry SE V6 Coupe (sold)
    Current: CamryAmp 2.0 - 98 Camry CE V6 5spd (still bench-testing)
      just found out
      the UM2801/UM2802 cost about 40 USD per piece. problem is minimal order is 6 piece. ouch.
      would love to use it to power my devices directly
      kao
        also need a circuit diagram
          *grin*
          it's as simple as
          connect 1)ACC 2)batter 3) ground to one end
          and connect the other end to your device
          of coz you should only use this for peripheries. coz the moment you turn off your ignition, the power shuts off.
          the other option is to pull a line from your PSU to act as power on/off
          come to think about it, that's a much better idea.
            If someone could confirm that this will work well. Then 6 shouldn't be difficult to sell within the community. $40 USD is damn cheap.
            mykolJay
            99 Accord coupe
            http://www.geocities.com/accordpc
            My Project Thread on mp3car.com
              I have already tested the UM2701 (similar to 2801 but without the on off) and it works great. will try to hunt down the 2801 on market before ordering from the distributor. they just requote me for 3 piece per order which works out to be 50+ per piece.... really need to think about this.
              but it's a lovely package to use. will post further when i find it.
              kao
                how big are these things...anyone know?
                mykolJay
                99 Accord coupe
                  50mmx50mm for the 2800 series
                  50mmx25mm for the 2700 series
                  can someone check with the US distributors to check the unit price?
                  http://www.umec-web.com/contact/cont.htm
                  kao
                    just to follow up
                    instead of waiting for the UM2800 series to come in, i decided to build a relay circuit for the UM2700 bits that i have.
                    managed to find a small relay and hook up the coil to 12v from the motherboard and the in from car battery. hook the out to the UM2700.
                    voila, i get a poor man's version of 2800
                    (just for price comparison, i got the UM2701 for 15 SGD (about 9 USD) while the UM2801, with similar spec except on/off circuit, it's 40USD at least)
                    hence, i will probably not bother with the UM2800 anymore
                    kao
