opus 150 watt PSU ?
  • opus 150 watt PSU ?
    Where did it go ? I tried finding it and it wasn't there I only chould find a the shuttle pc one would the shuttle pc fit in a normal case and wats the diff between this and the other one that mp3car.com had ?
    Later
    http://members.cardomain.com/superv
    1997 Toyota Corolla
    CarPC Prep Specs:
    Its all here
    Maybe they're gearing up for the 220W....and have run out of the 150W.
      That would be cool. Hope the 220w version will not fully comply with the ATX spec so it would turn off the 5v when the car is off.
      PowerVoice v1 | NaviVoice Source
      GammaControl v2.4
      SKINbedder v3
      1995 Lexus SC300
        I'm hoping for that too i'll email mp3car tonite
        1997 Toyota Corolla
        CarPC Prep Specs:
        Its all here
          It will comply with ATX, but you will have a jumper that will turn standby off. Plus it'll have remote trigger output like the some 90W ones have.
          I'll spout simplistic opinions for hours on end.
          Ridicule anyone who disagrees with me,
          and generally foster divisiveness,
          cynicism and lower level of public dialog!
            Sweet! And the EPIA SP comes out about the same time Now if I would just have money and time to get a LCD display (I'm leaning towards a used Xenarc because I will have to remove it from its case to make it look stock (I don't feel like resoldering the connections on a Lilli), and I don't want it failing).
            GammaControl v2.4
            SKINbedder v3
            1995 Lexus SC300
              so the 5v on the 150w is always on? is there a jumper on the 150w version to turn that off? Cause I don't realy like to have it like being always on...I guess putting a switch between the cable to the battery will fix that to...
                The standby power is always on per the ATX spec in the 150 watt OPUS. Searching around here find some work arounds if you don't like that.
                  ok, thanks Zip...but I don't realy get why they do that...won't that drain your battery?
                    because the ATX specs were designed for a PC not a car PC?
                    Signature: [==||========] 20% complete
                      But the Opus was designed for a vehicle and if they can put a jumper on the 90w, why not on all?
                      Laidback
                      The ultimate CarPC - Wow!
                        Possibly because the 150W came out before the 90W... and it was too late to make a change...
