Powering up normal ATX PSU
  • Powering up normal ATX PSU
    I need to install 2 lcd monitors and a portable dvd player in my wife's car and decided to hook them all up to a normal ATX PSU with molex connectors since they all work off 12v. I figured I could then plug the PSU into an inverter and hook the inverter into a switched 12v source in the car.
    When I tried the setup with the PSU plugged into an A/C outlet in the house, the PSU wouldn't power up. After trying a few PSU's and determining that they were all functional, I figured out that I coudn't get any PSU powered up without it being connected to a motherboard.
    My question is, how do you get a PSU to turn on without it being connected to a motherboard/computer?
    Thanks!
    Are you sure that's the way you want to go? it seems like a lot of work for no reason. if it's a portable DVD shouldn't it run off your car 12v system? Same for the monitors. What you might need is a regulator to get a constent 12v but if these are made for automobile use you probably don't even need that.
      theres 2 wires on the psu that you bridge to get it to power up w/o a mobo
      i remeber seeing a tutorial for running dual ATX powersupplies in a computer a while back.
      i dont know which wores though, sorry
        http://www.dslreports.com/faq/9208
        Just jump pins 13 and 14, see the page I linked to.
        2005 Ford Focus ST
          Short pin 14 to ground (pin 13).
          Y2K Accord Dell GX150
          EmoRebellion is a SCAMMER
            Do it all the time with a paperclip
            [H]4 Life
            I'm a lesbian too.
            I am for hire!
