earthing problem??
  • earthing problem??
    Removed my system from the car to do some updates.
    I'm using a standard PC power supply, to power the system, using the 12v line to the harddisk connector.
    Problem is when I have a monitor connected the system starts to boot, then the power supply shuts down.
    Runs fine when no monitor is attached.
    When it is running, and I touch the monitor connector to the VGA port or to the case the power supply shuts down.
    Used another monitor the same thing.
    It's seems to be a earthing problem, can anyone give me any suggestions
    maybe I have missed something.
    John
    More info:
    should mention what hardware i'm using:
    Sproggy 2.8
    via 800
    2.5 hard drive
    256 ram
    If I earth the pc case to the power supplys case, with no moniter attached
    I get the same think, so nothing todo with the monitor.
    I used two P/S same thing.
    it has run in the car for over a year with no problems.
    HELP
