A tank circuit qn + Relay qn.
  • A tank circuit qn + Relay qn.
    For a battery based tank circuit, if you use an SLA battery, what size are people using (how many Amp/hr?)
    Also, while ing for this, someone said "relays are bad" or something along those lines. (for use in isolating the tank battery). Anyone care to elaborate?
    92 Subaru Legacy Wagon
    Epia MII12000 :D
    Morex 80W
    120G External HDD
    16x2 Charater Display
    Creative IR Remote
    VIA Sereniti 2000 Mini ITX Case
    7.2Ah SLA Tank
    PCMCIA 802.11b
    256DDR Ram
    Diamonds are for girls- wise men follow the stars
    Sure.
    I'm using an Optima D34/78 battery:
    http://www.optimabatteries.com/publi...eep_cycle.html
    with 55 A/hr. This is overkill, yes, but I like the low internal resistance (0.0028 ohms) and supposed long life of the Optima.
    Relays are bad because:
    http://www.surepower.com/pdf/ebr_int.pdf
    This is SurePower's corporate advertising to an extent, but it is also informative.
    I bought a Hellroaring BIC95300A:
    http://www.hellroaring.com/bic75300.htm
    as an isolator. It is nice because it has no 0.7V drop going into the batteries as conventional solutions do, thus wasting less power and creating less heat.
    I have installed all this and it works fine, but haven't gotten around to the computer yet, so I can't tell you if this setup is good for the long term.
      anything is bad if not setup properly.
      ...come and join in:
      http://www.mp3car.com/vbulletin/show...1&page=1&pp=15
      danon
      [....99.9%]
      [HW] 566eMHz/128mb/6gb, FlyVideo3k, RandMgps, M1-ATX, 7" Lilliput, VGA2AVadptrFor2ndVideo, 4CH/100rms, 10"Sub, 40AhDeepCycleTank
      [....99.8%]
      [SW] XP/MMC/FP:D3,FlyTV/AxifeFM,CarMM?
      [Working on] puttingBackEvrythg.
        55A/h??????? Hmmm yes..... overkill and over what i want to pay (optima)
        Epia MII12000 :D
        Morex 80W
        120G External HDD
        Creative IR Remote
        7.2Ah SLA Tank
        PCMCIA 802.11b
        256DDR Ram
          And what about the price of the isolator? Ouch.
