Is my CD-Changer hooked up to ACC?
  • Is my CD-Changer hooked up to ACC?
    I currently have an alpine CD-changer in my trunk that has a power wire running to it. I'm going to remove it when I install my CarPC, but I'm wondering if the power line running to the CD changer is ACC? It should be, right?
    Carputer - 100% Complete!
    1993 Mazda MX-6 - 100% Totalled!
    Bought new 1995 Saab 900SE Turbo - Need new Micro ATX Case (Simple 101 case maybe?)
    Maybe. Could also be constant power, and receive a power-on signal from the headunit. Time to bust out the multimeter. If you don't have one, you can get a 12v test light for like $2. If you hook the light up and it won't light unless the key is turned to accessory, then it's accessory.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
      Awesome. Thanks for the tip! I will try that.
