temporary carpc, will this power setup work?
  • temporary carpc, will this power setup work?
    basically, i'm using a laptop i have lying around as my temporary carpc until i build one. I'll be using an 8'' lilliput with it.
    For power i'm going to use this adapter i got that plugs into my cig lighter and splits the connection so i can use both an AC source and a DC source (and also acts as a half-assed surge protector)
    I plan to use the AC portion of the splitter to power the laptop, and the DC portion to power the lilliput.
    Few questions i have about this are:
    1. will this be safe for my cars battery? I know my headunit turns off temporarily when the ignition starts, but does the cig lighter?
    2. By doing it this way, i know i'll have to manually turn on my laptop everytime i want to use the carpc.......anyway i can somehow get the laptop to turn on by itself with this setup?
    here's the product:
    http://www.tigerdirect.com/applicati...4004&CatId=237
    depending on your laptops power supply and that products ability to produce a clean AC curve, yr laptop should work fine, although i would say try to find a laptop DC-DC converter, they are more efficient and will probably work better.
    As for getting the laptop to turn on, there is a lot of information on this board, shutdown controllers that use the parallel port can be used to turn it off, as for turning it on, if the bios doesnt have a boot on AC power feature u may need to do some soldering to the power button connecting it to an ITPS or shutdown controller of yr choice (or relay with the ACC line).
    HTH, no1knows.
    Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
    Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
    CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
    http://www.no1knows.com/galleries/
