Laser printer in the car
  • Laser printer in the car
    Hi, I need some help here. Friend wants to install a laser printer in the car. So we though about using a invertor or capicator so it won't cause any problems with the car. Called the dealership and they said NO. So what am I left to do. I am thinking maybe there is some kind of battery pack that charges over time thru the cig lighter and loads up a battery pack to be able to handle the sudden large draw of power.
    I recall that laser printers pull a significant current.. I'd be impressed to learn that any given inverter could supply that kind of current.
    are inkjets out of the question?
    •Micke
      <levity>
      don't forget the scanner, and kitchensink...
      </levity>
      •Micke
        Check the power usage of the printer, then go and buy an inverter which is above those specs (make sure when getting the inverter you look at the sustained power, not peak) and wire it directly to the battery of the car.
        Half of the people at the dealership probably don't know the difference between their *** and their elbow (if it's anything like the place my dad used to work at), let alone doing something with the electrical system in the car.
        Garry
        Co-Developer of A.I.M.E.E
        www.aimee.cc
          LOL
          man I have no idea how to handle this one. I would assume you may be able to run it for short print job easily enough off an inverter. Then again I am not familiar with the power draw of a laser printer.
          Car: 2000 Audi A4 Avant 1.8t
          Carputer 2.0: removed. Back to stock.
            What about a laptop inkjet?
            Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
            Car PC Status: Complete - Undergoing Software Redevelopment
              what about a 2nd battery for it too?
                You can buy big invertors for lots of $$$. I have also seen generator ones, basically a 12v motor direct couples to a 120v generator. Saw one in an auto glass van to run a huge shopvac. You will expect to spend a $1000 or two for ones big enough to run a laser printer. Start looking at RV places, they have ones that can run microwaves, washing machines, etc.
                I have seen it done, I hired a guy to jackhammer my kitchen floor so I could run a new drain line (I weight less than a jackhammer so I needed someone bigger than me), stupid house built on a solid cement slab. He had a big Ford F350 box truck. The back had a workbench one side and he had a laptop and inkjet printer there and printed my invoice right there. I picked up a little HP350 for $5.50 and carried it in my truck for a while and could take it to customer sites to print stuff.
                  I think a laser printer draws huge current when the fuser is heating, it's huge like at least 600 watts.
                  Eugenen - I know I hate concrete slab floors also. I love basements, but here in California basements do not exist. I don't understand that in Ohio, however. My parents live in Wisconsin, and they have a basement.
                  Carputer currently 'ghettoed' into car!!!
                  EPIA MII-12000
                  Ampie Case with rigged extra USB
                  Hitachi 60GB
                  Holux GPS mouse with iGuidance 2.0
                  Lilliput 7" touchscreen
                  Netgear WG121 USB WiFi
                  Carnetix P1260
                    Or maybe a portable thermal printer? No ink...
                    Tidder
                    Try RevFE
                    I Wish I could ban people
                      OK....forget laser.....lets talk about inkjet.....or ANY type of printer....now what?
                        With Inject printer, you can just run off the 12V line on the PSU or a small inverter that you can plug in the adapter that comes with the printer.
                        I just don't see the need for lazer printer in the car or mobile environment.
                        The best option is getting one of those laptop printer.
                        Y2K Accord Dell GX150
                        EmoRebellion is a SCAMMER
                          If it stays in the car though, inkjet may not be the way to go, too high of temperatures... What would happen to the ink? That's why I was recommending the thermal printer.
                          Tidder
                          Try RevFE
                            And if it gets hot in the car what happens to the thermal paper over time?
                            Mind you, inkjet ink might freeze in the winter too. Be interesting to see what the thermal limits of inkjet printers may be. I still think this is your best bet.
                              Hmm... I don't think it'll get hot enough in there to screw up thermal paper... But thermal paper is more expensive.
                              Tidder
                              Try RevFE
