5 volt power supply for accessories
  • 5 volt power supply for accessories
    I needed a 5vdc power source at 1.5a for my Audigy 2NX soundcard. The Carnetix supply only feeds 12v to my Epia/Travla unit. I bought a automotive power adapter for the HP Ipaq pda for $22 and it supplies 2amps at 5vdc without any heat problems. I cut the cable which holds 2 red, 2 black, and 1 yellow wire in it. Combine the reds for 5v+ source and combine the blacks for a ground (didn't use the yellow and don't know what it's for). Voila, it works great!
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
    cool!
      Yellow was probably for data.
        huh, good idea.
        Tidder
        Try RevFE
        I Wish I could ban people
          If you've got a Lilliput, then make good use of the egg that it comes with!
          Click me!
          Garry
          Co-Developer of A.I.M.E.E
          www.aimee.cc
