ITPS reprogramming ?
  • ITPS reprogramming ?
    Hello,
    i will reprogrammning my iTPS device, then 45 seconds is for me to fast.
    is my new programm right or id there a ather way to programming the turn of secuence make to 13 for switch shutdown and 15min for hard power off ?
    my programm
    ONDELAY equ .5 ;power on delay 1 seconds
    ONDELAY2 equ .5 ;wait 1 second until push button
    BUTTON equ .1 ;push button for 400 ms
    OFFDELAY equ .3900 ;shut down 13 minuten after ignition off
    HARDOFF equ .4500 ;hard off after 15 minuten
    Old programm
    ONDELAY equ .20 ;power on delay 4 seconds
    OFFDELAY equ .25 ;shut down 5 s after ignition off
    HARDOFF equ .225 ;hard off after 45 seconds
    Naruto
    I dont know what version of firmware you have but what you propose wont work. The program wont take in more than 255 for the delay because its only working within a single byte.
    You will need to add code such that it will loop a much longer delay. Or make a delay that take in 2 bytes values up to 65535 delay value.
    Im sure theres a modified ITPS firmware that do this, ask around
      i search the forum before and the only was i found is from brooksware2000 that he will post a programm this was at june
      Or a Power ON/OFF Programm from you
      My problem is i have no programming knowlage to programming the ITPS complete new with a loop.
      When there is a FW that has a longer shutdown sequence please sent me the HEX file.
      THX
      Naruto
      P.S. my Firmware what i use was the FW from itps3.zip
        I cant remember the name of the user who got hold of the modified firmware from the ITPS company.
        The firmware is supposed to have a longer time delay.
        Start a thread or something...or else mail the ITPS guy for the longer delay version of their firmware. Im 99% it does exist
          I wrote to sipport@mini-box.com i found no other adress
          Cu
            Hi,
            i progged with RedZac from another forum a modified fw over a variable there is a shutdown time from 1min to ..... min
            THX
            Naruto
              What forum was that? Any more details?
                Hi,
                this forum http://www.car-pc.info/phpBB2/viewforum.php?f=5
                when you need the programm, please send me a pn with your email and i sent you this programm,
                i dont know of right it alowed to put the fw on the forum ?
                The FW has a new variable for min shut down easy way for all times 1 min to xx
                cu
                Naruto
                  Thanks, unfortunately my German is a little rusty
                  I also dont know about the legality of posting the firmware; but others have posted firmwares before... Anyway, i sent you a PM...
                    OK here is the source
                    ; Ituner power sequencer
                    ; Modifiziert von Michael Forter und Naruto
                    ; pd 030611 initial code
                    LIST p=12F629 ;Target processor
                    #include "P12F629.INC" ;Header file for target processor
                    ; GP0 = VSW12 input 1 = ignition turned on
                    ; GP1 = ON output 1 = turn power on
                    ; GP2 = MBON# o.d. 0 = power button pressed
                    ; GP3 = n.c. input
                    ; GP4 = MBON2# o.d. 0 = power button pressed (parallel out,
                    ; makes connector flip-tolerant)
                    ; GP5 = n.c. output 0 = terminate unused pin
                    ; Schutdown Zeit einstellen die länge kannst du im wait3 oder im wait2 ändern
                    ; wait1 ist ca. 250ms
                    ; wait2 multipliziert mit 255. also 255 mal 250ms
                    ; und wait3 das ganze nochmals mal timeoff
                    ; Equates
                    PWR_OFF equ 0x00 ;power off state
                    PWR_ON equ 0x02 ;power on state
                    SW_ON equ 0x09 ;direction for switch on
                    SW_OFF equ 0x1d ;direction for switch off
                    ONDELAY2 equ .2 ;wait 800ms second until push button
                    OFFDELAY equ .5 ;shut down 5 s after ignition off (nicht mehr so wichtig wg Timer)
                    timeoff equ D'10' ;ca. 10min Pause 1= 1,02 min HIER ÄNDERN FÜR ABSCHALTDAUER !!!
                    ; Register variables
                    cntr equ 0x20 ;state counter
                    cntr2 equ 0x21
                    waitl equ 0x22 ;delay counter low
                    waitm equ 0x23 ;delay counter mid
                    waith equ 0x24 ;delay counter high
                    loops Equ 0x25 ; Zähler für Warteschleife
                    loops1 Equ 0x26 ; Zähler für Warteschleife
                    loops2 Equ 0x27 ; Zähler für Warteschleife
                    loops3 Equ 0x28 ; Zähler für Warteschleife
                    ; reset entry
                    org 0
                    goto reset
                    ; interrupt entry
                    org 4
                    retfie
                    reset
                    banksel OSCCAL ;get oscillator calibration
                    call 0x3ff
                    movwf OSCCAL & 0x7f
                    movlw b'100000' ;enable weak pull-up on
                    movwf WPU & 0x7f ;GP5 (doesn't seem to work...)
                    movlw b'00001101' ;set option register
                    ;enable weak pull-ups
                    ;timer0 internal clock, positive edge
                    ;prescaler -> WDT, 1:32 -> ~0.5s
                    movwf OPTION_REG & 0x7f
                    reset2
                    banksel TRISIO
                    movlw SW_ON ;set pin directions
                    movwf TRISIO & 0x7f
                    banksel GPIO
                    movlw PWR_OFF ;set initial state
                    movwf GPIO
                    movlw 7
                    movwf CMCON ;disable comparator
                    clrwdt ;clear watchdog
                    ; initial state - wait until ignition is on for ONDELAY
                    initial
                    banksel GPIO
                    movlw ONDELAY ;initial power on
                    movwf cntr
                    initwait call delay200 ;wait
                    btfss GPIO,0 ;ignition on ?
                    goto initial ;no: clear counter
                    decfsz cntr,f ;initial time-out
                    goto initwait
                    ; turn power on, wait ONDELAY2
                    turnon movlw PWR_ON
                    movwf GPIO
                    movlw ONDELAY2 ;wait for ONDELAY2
                    movwf cntr
                    turnon1 call delay200 ;wait
                    decfsz cntr,f
                    goto turnon1
                    goto reset2 ;no: turn off again
                    ; push the system board power button
                    banksel TRISIO
                    movlw SW_ON ;push the button
                    movwf TRISIO & 0x7f
                    banksel GPIO
                    movlw BUTTON ;wait for BUTTON
                    movwf cntr
                    button1 call delay200 ;wait
                    decfsz cntr,f
                    goto button1
                    banksel TRISIO
                    movlw SW_OFF ;release the button
                    movwf TRISIO & 0x7f
                    banksel GPIO
                    ; power on state - shut down if ignition off for OFFDELAY
                    onstate movlw OFFDELAY
                    movwf cntr
                    onstate1 call delay200
                    btfsc GPIO,0 ;ignition on ?
                    goto onstate ;yes: reset timer
                    decfsz cntr,f
                    goto onstate1
                    ; Warteschleife für Power OFF
                    Wait3
                    movlw timeoff ; zeit wie Variabel
                    movwf loops3
                    Wait2
                    movlw D'255' ; 63,75s Pause
                    movwf loops2
                    Wait1
                    movlw D'125' ; 250 ms Pause
                    movwf loops1
                    Wai
                    movlw .220 ; Zeitkonstante für 1ms
                    movwf loops
                    Wai2 nop
                    nop
                    nop
                    nop
                    nop
                    clrwdt ;Watchdog reseten
                    decfsz loops, F ; 1 ms vorbei?
                    goto Wai2 ; nein, noch nicht
                    decfsz loops1, F ; 250 ms vorbei?
                    goto Wai ; nein, noch nicht
                    decfsz loops2, F ; 63,75s vorbei?
                    goto Wait1 ; nein, noch nicht
                    decfsz loops3, F ; 14.875min vorbei?
                    goto Wait2 ; nein, noch nicht
                    onstate3 movlw OFFDELAY
                    movwf cntr
                    onstate2 call delay200
                    decfsz cntr,f
                    goto onstate2
                    ; shut down - push the system board power button
                    banksel TRISIO
                    movwf TRISIO & 0x7f
                    banksel GPIO
                    movwf cntr
                    button2 call delay200 ;wait
                    decfsz cntr,f
                    goto button2
                    banksel TRISIO
                    movwf TRISIO & 0x7f
                    banksel GPIO
                    ; turn-off state - turn off power after HARDOFF
                    ; go back to restart after ONDELAY
                    movlw HARDOFF
                    movwf cntr
                    movlw ONDELAY
                    movwf cntr2
                    shut1 call delay200
                    goto shut2 ;:no
                    decfsz cntr2,f
                    goto turnon ;go turn-on if ignition on for ONDELAY
                    goto shut3
                    shut2 movlw ONDELAY ;ignition off - restart on timer
                    movwf cntr2
                    shut3 decfsz cntr,f
                    goto shut1 ;keep waiting
                    goto reset2 ;do hard power off
                    ; retlw 0 ; das Warten hat ein Ende
                    ; 200 ms delay routine
                    delay200 clrwdt ;tickle the watchdog
                    movlw .1 ;note count is +1 (decfsz !)
                    movwf waith
                    movlw .0
                    movwf waitm
                    clrf waitl
                    del1 decfsz waitl,f ;delay loop - 3 us per iteration
                    goto del1
                    decfsz waitm,f
                    goto del1
                    clrwdt
                    decfsz waith,f
                    goto del1
                    retlw 0
                    ; oscillator calibration - comment out for production !!!
                    ; org 0x3ff
                    ; retlw 0x94
                    ; define configuration bits
                    __config _MCLRE_OFF & _CP_OFF & _WDT_ON & _PWRTE_ON & _INTRC_OSC_NOCLKOUT
                    ; external reset off
                    ; code protection off (not read protected)
                    ; note: if code protection is switched from on to off, OSCCAL
                    ; value is erased too !!!
                    ; watchdog timer enabled
                    ; data memory protection off (not used)
                    ; internal RC oscillator
                    ; brown-out detect enable
                    ; power-up timer enable
                    END
