How many amps needed to power carputer?
  • How many amps needed to power carputer?
    I have stored my car for the winter so I have my carputer back at my place. I want to be able to hook up the carputer inside so I can set everything up the way I like it for the spring.
    I tried connecting my opus 90w to a power inverter which gave out 12v and 2.0 amps. Obviously that wasn't enough amps. How many amps would I need from an inverter for this to work? Or, how do you guys connect your carputer outsde of your car?
    I have:
    m10000
    40gb laptop drive
    512mb ram
    opus 90w
    audigy 2 zs (on a riser card)
    Thanks,
    Joe
    http://www.cardomain.com/id/msumr282
    I have:
    m10000
    40gb laptop drive
    512mb ram
    opus 90w
    Thanks,
    Joe
    Get a ac/dc PSU and jumpstart it and plug it into a 12v line.
      You need to find a 13.8v power supply that gives at least 5-7 amps continuous from an electrinics shop.
      Thats what I use indoors, aand I find my setup draws about 5 amps to start and then settles down at 3-4 amps depending on what its doing..
      Steve
      ....Yes, I know it has a stupid name, those crazy Japanese!
        90/12V = 7.5Amps. So I would get a a powersupply that supplies anywhere between 12-14V to the opus at 10 amps. Ofcourse, thats assuming your maxing out the Opus.
        Mark
        Website: http://www.greenpowerenthusiast.com/
        Car'Puter Project
        - Xenarc 700TSV
        - MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
        - 1x 256MB Corsair XMMS DDR400
        - M2-ATX
        - Belkin 802.11G W-Nic
        - Garmin 15H GPS
        - WinXP SP2 (NLited)
          Radioshack has exactly what you want for about $40.
            thanks guys
              Why not just spend $25 and buy a regular power supply?
              ATVMS.com
                No ****.... You cand find them in dumpsters nowdays if you look hard enough
                Current Setup
                Nexus 7 Tablet
                Built in head unit
                Brutus 1500Watt Amp
                Two Boston 12" subs
                2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
                  I found a power supply that was for an old pair of my multimedia speakers. It has an output of 12vac and 3000mA. I'm not familiar with mA. Will this work or would it be too much/too little power? If it the right amount of power, I would just cut off the end and splice it into the opus 90w.
                  Joe
                    nm, thats AC. duh
                      It is probably DC but not nearly enough amps to power your computer. Go to the computer store and buy a power supply.
                      ATVMS.com
                        3000mA = 3A
                        just like 3000mm = 3m
                        and yeah, dont use ac :P
                        Signature: [==||========] 20% complete
                          I just use my old trusty charged Yuasa 12v 17.2Ah battery to power the CNX-1260
                          Carputer currently 'ghettoed' into car!!!
                          EPIA MII-12000
                          Ampie Case with rigged extra USB
                          Hitachi 60GB
                          Holux GPS mouse with iGuidance 2.0
                          Lilliput 7" touchscreen
                          Netgear WG121 USB WiFi
                          Carnetix P1260
