How many wires go to the shutdown controller?
  • How many wires go to the shutdown controller?
    I'm going to put in a shutdown controller that will power down my computer and my inverter.
    The shutdown controller obviously needs to be hooked up to a switched power source so it knows when the car is on and off.
    How many wires go to the shutdown controller from the switched power? Is it just one wire from say the head unit that tells the shutdown controller to start up? Or do there need to be two wires?
    Here it is! My carputer install! 1997 BMW M3
    this is what i did:
    http://www.vcbb10.info/ShutdownController
    that's the most recent with pics of my shuttle wired up. I didn't use a cap, so no delay, but it shuts the inverter off after the computer shuts down (leaves on if computer hangs, but that shouldn't happen...much )
    Also uses this for com port trigger: http://www.mp3car.com/vbulletin/show...own+controller
    more in-depth info: http://www.mp3car.com/vbulletin/show...&page=3&pp=10&
    My Mazda 3s
    My Mazda 3s on Car Domain
    [||||||||||||||||||--] (90%)
      Thanks for answering, but can you translate all those colored lines into english? haha It's 1:30 am and I've been at this for hours. I no longer have the ability to read wiring diagrams. Is there one wire running to the shutdown controller or two?
        Which Shutdown Controller are you using?
        Here is some info for the Mpegbox one:
        http://www.mpegbox.com/microsdc/Inpu...ionSchemes.pdf
        Also:
        www.mpegbox.com/microsdc/Quick User Guide 1.pdf
        www.mpegbox.com/microsdc/usdc20d.pdf
        MPEGBOX - Plexiglass Computer
        www.mpegbox.com
          Simple answer:
          Three. One constant on +12volts. One ground. One switched (like the accessory line).
          KyferEz
          www.thecarpcstore.com
          TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
          PSU Wattage Calculator
          Electronics Calculators
          Copper Wire Data
            The DSSC only requires 3 wires: Constant 12v, GND, and ACCessory.
            To turn on additional devices, such as Amplifiers, USB hubs, etc. You'll require one connection between the DSSC and each respective device. These connections are optional, however.
            Kind regards,
            Chris Bergeron
            DashPC - The Linux Car (since 1999).
            Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
            As seen in the book Geek My Ride
              Typical application with Inverter
              Here is a connection diagram for the DSSC. This image is of an installation using an inverter and the PC's power button (ACPI). DC-DC power supplies would be connected similarly by substituting the Inverter with the DC-DC power supply (ie, Opus, etc).
              Hope this helps!
                Well, since we're all in this fourm, the Mpegbox one only requires 2 wires per a few of the diagrams I posted. Ha!
                +12 and Ground.
                You can add a switch to Accessory or just tie them together.
                -Jeff
                www.mpegbox.com
