250watt dc dc supply
  • 250watt dc dc supply
    Car Tft sell 250 watt power supply. 188. (atx connecter P4)
    heres one to
    http://www.zantech.com.au/apowertech/PSU-12vdc250w.html
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
      This is going to sound really stupid but I've been out of the PC thing for quite some time. Will the P4 ATX connector work with a AMD ATX Motherboard?
        yes i think so but AMD chips are alot more power hungry than an intel so you will have to do a watt count on all your bits to see
        The car
          A duron Xp is not a preshott.
          Now Galileo is real. Muhahahahaha :p
            The ATX connector fits any ATX system board, the P4 connector is a seperate thing and only needs to be used if you have a P4.
            Laidback
            The ultimate CarPC - Wow!
