Car Battery *what to buy*
  • Car Battery *what to buy*
    I currently have:
    p1.5
    opus 150
    about 8 usb connections being powered
    400 watt amp
    2002 impreza
    all running off my battery,
    but i'm having issues where the opus will not endure a crank,
    and i sometimes get random shutdown times (system only runs for 5 minutes tops without the engine on)
    So i need a reccomendation as to what type of battery i should get for my car... (something of quality and fitting for the carputer enviroment)
    I have zero knowledge when it comes to cars...
    any help here?
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    I have always had the best luck with Optima batteries. They are very durable in all ways except deep discharging. The Yellow would be my recommendation for running a carpc.
    2005 Ford Focus ST
      Optima is a good option for sure.
      If you want a little more power though:
      www.kinetikpower.com
      just thought I would throw it out there.
      Jan Bennett
        OOoooolala...
        those look sweet!
        2005 Ford Focus ST
          JUST bought an optima yellow top today... freaking only pepboys had the size I needed (D51R).
          And before you try to buy from websites, check teh info direct from the site that speedracer sent. It seems that every freaking website has the wrong picture for the D51 and the D51R. (the two terminals are switched) So I almost ordered the wrong one from an online site cause the picture was inaccurate.
            man - I can't imagine what shipping must be like to order a battery from an online site.....
            Jan Bennett
              Check out Odyssey Drycell.
              http://www.odysseybatteries.com/
              I am putting one in this week. I have a friend who own a truck electric shop, and he said he likes these even more than the optima.
              I am installing the PC 1200 as an auxillary.
              Planar 12.1TS
              Xenarc 700TS
              Xenarc MP-SC8 Mini P4 Aluminum Car PC
              Sound Blaster® Audigy® 2 NX
              2.8 Celeron D
              512 PC2700
              Dual Odyssey 1200s for Power
                costco sells optima batteries. I haven't seen Optima Yellow, but they do sell Blue.
                You should be fine with a redtop.
                [ 5-spd 1996 M A X i M A SE ]
                  batteries.com actually has cheap s/h for the optima... for ground, it's FREE! next day is only $25. But I did check some other sites... yeah $30 or so for ground, $80 or so for next day, F that.
                    ....uhhhg..
                    alright being the cheap bastard that i am...
                    what would you reccomend for a step down from teh optima's,
                    or something a little more price friendly
                      $110 is too much for a battery?
                      The next step would be to just go to your local shop and pick up a battery.....you're looking at $65ish then.....
                      totally worth the extra money, hands down, for the optima
                      Jan Bennett
                        My problem and solution is on this thread.
                        http://www.mp3car.com/vbulletin/showthread.php?t=38028
                        For short: Optima battery either Red top or Yellow.
                        Y2K Accord Dell GX150
                        EmoRebellion is a SCAMMER
                          fine... fine..
                          I'll shell out for the optima,
                          be back in a bit
                            I'm just saying, if it means you won't be able to eat, then don't do it.....but if you do have the money avaliable don't go cheap, you will regret it
                            Jan Bennett
                              i'm just gonna live on tuna cans and ramen for the next couple weeks,..
                              don't worry bout me...
                              i'll be fine.....
