Why shutdown controler?
  • Why shutdown controler?
    I want use carputer while is engine off.. And I dont need automatical shutdown after stoping engline..
    Whitch powersuply should I buy?
    what components are you using?
    we need to know how much power you will need before we can recomend a PSU....
    Jan Bennett
      yeah but you'll be wanting the pc to turn ON with your ignition won't you?
      Destinator 3 For PC! - http://www.map-monkey.co.uk/
        Via M10000 and 3.5" 120GB HDD
          mashina, you should have done a little browsing or searching. The answer was in one of the top 3 threads in this forum:
          use the online power calculator at http://www.thecarpcstore.com/link.ht...alculator.html to figure out your wattage requirements.
          Then browse some of the power supplies mentioned and in the store. If you still have questions, search for a bit, then ask if you still haven't found the answer you are looking for.
          Don't get me wrong, I'm not flaming you or anything, just asking you to do a decent amount of searching first
          ColdPhreze
          14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
          200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
          2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
            yes it would be fain, but really I dont need this.. i need survive engine 'function' and good cost
              See this thread on surviving crank:
              http://www.mp3car.com/vbulletin/showthread.php?t=38973
              And as for why a shutdown controller?
              1) life is easier when you don't have to wait for the pc to shutdown everytime you go to get out of the car at the store/movies/etc.
              2) To make sure your battery isn't dead because you forgot to shut off something.
              3) To help prevent the thump that occurs in the amps from turning on the pc.
              4) To help prevent hard drive data corruption by preventing the pc from running in extreme temperatures (high or low).
              ColdPhreze
                mashina,
                you need to describe your system in order for us to help advise you better. How much power do you need? What mobo/processor/accessories are you using?
                My Celica Carputer Install
                  Hi
                  I have bought M1-ATX. i payed it at 1.1.2005 and today the PS come. I connected it to mobo and +- .. and .. i dont know whitch word i should to use my english is too bad.. so the ps didnt work.. one of the condenser started to fry and somethink yellow was 'splashing' from it. because I frpom czech republic and I know only one carputer shop (cartft.com in germany) and the express servivce cost 20.. i have repaired it myself.. I bougt new condenser 35v, 470uF . i cant belive it, but now the ps is ok!
                  really oskar story or not?
                    good job mashina.
                    ColdPhreze
