Car neons on house plug
  • Car neons on house plug
    Sorry if this is a stupid question.
    I know you can get convertors to power laptops on the cars 12v supply but can you do the reverse?
    Have some car neons that I want to mount in the house (under a pool table to be exact) and would like to know if possible of the UK socket (240v I think)or alternatively run off the PC's PSU.
    Don't fancy having them blow up in my face.
    cheers
    any 12V DC will work. You could even use a PC power supply ( as long as you jump the two pins to turn it on.. not sure which it is on an ATX, maybe someone can post to remind me.)
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
      Like Custommx3 said, any 12V DC output wall plug will work. Just make sure the output has enough Amp to drive those light. I remember seeing the wall plug with cig lighter socket type output.
      If you use the PC PSU, look for the Yello and Black wire on the drive power connector. Yellow being + and black = -.
      Y2K Accord Dell GX150
      EmoRebellion is a SCAMMER
        Im referring to using a PC power supply as a stand alone. To getthe molex power working, you have to jump two wires on your ATX motherboard connector.
          http://forums.thatcomputerguy.us/lof...php/t1120.html
          I GIVE FREE HUGS!
          Buy Sell or Trade
          If my pm box is full, please feel free to call me any time. 440-328-3382
          Thank you
          Forex
          Rate Mp3car @ FXroot.com
            The only green one and ANY black one.
            I'm pretty sure those neons dont draw alot of power. I have 3/4 for my streetglow kit, let a friend drive and he busted the front one GRR. I've been considering using the other 3 in my room as light instead of the regular bulb. Neons dont usually take much power to run, its just the converter from 12V DC to 2000VDC or something. Not sure what the numbers really are, but it has to make it a huge voltage number
            EDIT: Bah too slow.
