Case Travla and Internal Power supply
  • Case Travla and Internal Power supply
    Does anyone know if the internal power supply of travla cases need and external regulator or not?
    Folagana
    Yes, they do.
    2004 4runner
      Originally posted by rando
      Yes, they do.
      you mean I have to buy also an external stabilazer right?
        They come with a house adapter, and yes they do have an external converter.
        Renault Megane...the OEM look
          The supplies require a regulated 12V input. They come with a standard AC wall wart for in-house (or inverter) use. To run without an inverter in your car, you'll need a 12V regulated supply such as the Carnetix.
          2004 4runner
            Depends on which case you're talking about. The C137 requires 19VDC input.
            System status: in progress
              Fine, either way the answer to his question is the same. The supplies need an external regulated supply.
              2004 4runner
                thank you to all
