Xenarc - USB Power cable?
  • Xenarc - USB Power cable?
    For powering the Xenarc, I am going to fabricate a USB power cable, to run from the Opus (located in the back) to the front.
    For the USB power cable, I am going to do the following:
    • Take USB cables from old USB LAN adapters
    • Splice cables together to get correct length
    • Create a PCB or similar to connect power cable to custom Power USB port
    • Connect custom USB power port to Opus 12v & ground
    Seems like it will work just fine. Anyone got any inputs?
    What's wrong with a speaker wire feeding the GND and PWR?
    Have: Via Epia M10000 1GHz|512Mb|20Gb|Slim slot-loading DVD-R|Carnetix P1280|RevCam|GPS|Illum’d keyboard|11g Wifi
    Waiting for: Xenarc TFT in-dash (haha!)
    Status: Finalising component procurement
      Wouldn't it be easier to just extend a molex connector?
      Although, I wonder if you'd be able to splice into the USB used to connect the touchscreen....
      http://www.jeepmp3.com/
      CarPC Stolen. Starting over.
      Ne1 recognize the avatar?
        I want a way to plug/unplug the power line from the computer.
          Yea maybe, but like i just posted, i want to plug/unplug it from the computer. I am basically using the USB end as the lug: and the other end splice into the chopped off cigarette adapter
