shutdown command through parallel port
  • shutdown command through parallel port
    Is it possible to tell windows to shut down via the parallel port? How about a USB port? Both serial ports are being used already
    Chris Krug
    owner, turbine minivan
    http://www.youtube.com/krugtech
    You could use a USB keyboard with a power button. Or you could get a USB->Serial dongle and use the built-in UPS service to shutdown windows. Alternatively you could write some code to monitor whatever port you want and shutdown windows.
    2004 4runner
      TurboChris, you can shutdown your computer using the parallel port with the DSSC shutdown controller. We can provide you with code and examples of how to do it using our controller.
      It's simply a matter of connecting 2 wires from your parallel port to the DSSC to make it shut down properly.
      Kind regards,
      CB
      DashPC - The Linux Car (since 1999).
      Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
      As seen in the book Geek My Ride
