My carputer does not come on any more
  • My carputer does not come on any more
    well i just installed my carputer about 3 days ago and had been working great. But today i turned on my car and it froze on the epia loading screen for the motherboard. So i unlplugged the power from the motherboard. After that when i turn on the ignition again, the usb devices will power up. Then about 2 to 3 seconds when the opus sends the signal to turn on the computer, the power supply just dies and a loud pop sound goes through the speakers. I have to unplug the power for about 20 seconds and the led on the opus will start flashing again and it will go though the same crap again. Can anybody please help me with my problem.
    how many flashes?
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
      it blinks like normal before you turn on the ignition, then when you turn the ignition, it stays on constant and then it dies with the loud pop noise.
        hmm i dont know what it is supposed to do when wired to your ignition/acc switch wire. Mine is wired to a switch. Mine light stays on constantly when the switch is flipped.
        Also what do you mean when you unplug the power from the mobo, that the usb devices work?
        I GIVE FREE HUGS!
        Buy Sell or Trade
        Thank you
        Forex
          well i don't have a reset or power button to restart the computer, so i just unplugged the cable coming out the power the supply from the motherboard.
            im sorry im not that much help with you guys i just installed my opus today. What happens when you turn your key off?
            I GIVE FREE HUGS!
            Buy Sell or Trade
            Thank you
            Forex
              well on mine, after ignition was turned off, in 20 seconds it would shut down.
                ive never played with the jumpers. there is a setting for 10sec delay. Id like to figure out how to read opus's guide on settin them.
                I GIVE FREE HUGS!
                Buy Sell or Trade
                Thank you
                Forex
                  You probably should have used a startup/shutdown controller in your install.
                  Something like the DSSC works perfectly with the OPUS, and it prevents situations like this.
                  Hope this helps.
                  Kind regards,
                  CB
                  DashPC - The Linux Car (since 1999).
                  Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
                  As seen in the book Geek My Ride
                    Well I just figured on my carputer, I accidentally kicked the case and it arbi-booted. I think you probably have some connector flying out partially!
                    Carputer currently 'ghettoed' into car!!!
                    EPIA MII-12000
                    Ampie Case with rigged extra USB
                    Hitachi 60GB
                    Holux GPS mouse with iGuidance 2.0
                    Lilliput 7" touchscreen
                    Netgear WG121 USB WiFi
                    Carnetix P1260
