PW70A (Blown) Some help please
  • PW70A (Blown) Some help please
    Hey
    I was messing around on the weekend and ended up touching my 12V line to ground and blew the power supply. Does anyone know the schmatics on this thing. So i can replace componets instead of buying a new one.
    If not I am just going to buy and Opus.
    Gord
    you may be better off replacing it ...
      There also may be a surface mount fuse. The PW-60 units have a fuse that blows if you do just that sort of thing. It is close to the power connector on the PSU; and this is just an assumption, but the PW-70A may also have one.
      KyferEz
      TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
      PSU Wattage Calculator
      Electronics Calculators
      Copper Wire Data
        Yes I know about the fuse but that is on the input
        I touched the +12V on the output.
          I solved the problem
          On the PW70A there are 3 fuses
          1 on the incoming 12 V line
          The one I blew was F3 I guess it is hooked up to the output line
          Im guessing the 3rd on is on the 5V line
