Power Question
  • Power Question
    Hi Guys,
    Im sure you are all pretty sick of these threads but can you please help a newbie
    Im planning on running the following components for a car-pc, and my question is will the OPUS 150W PSU handle it?
    CPU
    Pentium 4 3.0EGhz
    Motherboard
    Asus P4P800s-x
    http://www.asus.com/products/mb/sock...x/overview.htm
    HDD
    Western Digital 80Gig (Full Size)
    DVD Drive
    Lite-on 16x (Full Size)
    RAM
    512mb
    Video Card
    Asus Radeon 9550
    PSU
    Opus 150w
    Well thats about it, Thanks in advance for helping me out.
    You can calculate it:
    http://www.thecarpcstore.com/link.ht...alculator.html
    But the answer is: it may work, but _if_ it does, it will have a short life.
    KyferEz
    TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
    PSU Wattage Calculator
    Electronics Calculators
    Copper Wire Data
      ok thanks
      Heres what i got after using the calculator
      "Your Recommended Minimum Power Supply is 224 Watts Peak !!"
      So thats a no go for the opus 150w?
        You're using a full-sized mobo anyway, so unless you're building a custom case, you will have no problem with a full-sized DC-DC atx ps.
        http://www.jeepmp3.com/
        CarPC Stolen. Starting over.
        Ne1 recognize the avatar?
          PatO is making mention of (I think) a PSU such as the Keypower 250watt. When using one, you will need (want) a separate shutdown controller, such as the CarPC EZ or Pro to turn on and off everything with the car.
          KyferEz
          Copper Wire Data
            ok thanks I'll look into that.
            I just came accross the website
            http://www.hossweb.com/Vehicles/Expe...0CarPC%203.asp
            Looks like he's running quite a few components off a standard ATX mobo using an OPUS 150w..
              Yes, he does, but there are 2 differences:
              1) His OPUS won't last long; he is overstressing components by running that much off of it.
              2) He is running a 2.4GHz vs. your 3.0GHz. He doesn't mention which P4 he is using either, and that makes quite a bit of difference.
              KyferEz
              Copper Wire Data
                ok well it looks like its back to the drawing board
                I really want to use the Opus psu because its alot easier to use.
                Should I be looking at a mini itx system instead?
                I basically want to use the system for DVDs and mp3s using Windows XP MCE 2005.
                Any help choosing components would be greatly appreciated.
                  Take a look at the M12000 and M10000 motherboards. They are perfectly adequate to play DVD and Divx movies, at least on Win XP. As for MCE 2005, if it keeps in MS tradition, will require more resources and may not play Divx as well.
                  You can play mp3s on nearly any pc.
                  The big difference between the mini itx systems and the 3ghz pc is that you won't be able to be watching a movie, have gps map up, and be able to switch quickly between them. Quickly being the key word.
                  The other option is using a Athlon MP processor. They consume much less power, and you will still be able to have a fast PC.
                  KyferEz
                  Copper Wire Data
                    Go with a MicroATX mobo and AMD Athlon mobile CPU. That combination will be fine with Opus 150W.
                    Y2K Accord Dell GX150
                    EmoRebellion is a SCAMMER
                      Thanks for the help!
                      Ok, ive got a micro atx system I think should work
                      Asus A7N8X-VM-400 Motherboard
                      AMD Athlon Mobile 2500+ CPU
                      WD 80Gb HDD 3.5"
                      Lite on DVD Drive (full size)
                      512MB RAM
                      Powered by an OPUS 150w
                      Hopefully that works!
