dropout - dead end links
  • dropout - dead end links
    Well....I've searched and searched, and have become tired of the dead-end links on the site. I can not seem to find the solution to my problem, which has definately been discussed in this forum to great extents. My computer is now dropping out more and more frequently...mostly when I stop at a light or park. I'm using an ITPS and PW-70a. Can anyone please explain what could be my problem? I have a feeling the ITPS is reacting wrong to a voltage drop. Do you think it's the wiring, ground, etc... Thank you in advance!
    Via epia M10000
    12.1" VGA touchscreen
    XP Pro
    OPus 150W
    120 GIG Maxtor
    512 DDR
    Geforce 5500 Videocard
    Audigy NX USB sound card
    Wireless Keyboard & mouse
    Panasonic slim line -slot load
    w/ usb adapter
    IRMAN
    I think you're right.
    Have you acted on your theory?
    How about the Wiki?
      well. I didn't actuall install this, so I am trying to pack up as much info as i can and give it to my friend to troubleshoot.
      Via epia M10000
      XP Pro
      OPus 150W
      120 GIG Maxtor
      512 DDR
      w/ usb adapter
      IRMAN
        I've got the same prob. If I find the answer I'll let you know. I bought a 1farad cap and hooked up to my amp, helped a little, but I'm I'm at a stoplight with my headlights on, and hit a hard note, mine dies too.
        Tidder
        Try RevFE
          I'm sure this has happened to so many people...does anyone out there have a good idea how to resolve this?
          Via epia M10000
          XP Pro
          OPus 150W
          120 GIG Maxtor
          512 DDR
          w/ usb adapter
          IRMAN
            I think I'm gonna grab a higher output alternator and see if that fixes my problem. I'll let you guys know if it does.
            Tidder
            Try RevFE
              I would check your battery's voltage with all the lights on, at idle and while your bass is pumping.
              A quality battery just might help. Make sure that your altinator or sepintine belt belt is tight and in good shape
              My Install
              Software:
              CFiG v1
              iGuidance Plugin for CF
              CarShell
              Working shell for a CarPC
              StopWatch
              StopWatch plugin remade for centrafuse RC1
                When idling without the PC on, I see 13.75V from my car battery. With PC on (about an 8A draw), I see 12.75V. When the cooler kicks in to help cool the engine because there's no airflow due to movement, it drops to 12V. I don't have a powerful amp and wasn't playing music in these measurements.
                I bet your battery and/or alternator probably can't cut it and the ITPS is shutting down due to low voltage.
