Inverter Question
  • Inverter Question
    So I have a 400Watt inverter powering up my carputer right now, and there is a problem.
    1. It will do a very high pitched WEEEEEEEEEEEEEEEEEEE noise after about 15 mins and it will last until I turn it off any ideas?
    2. If I leave just my inverter on, will it keep draining my car's battery for 400W even when my computer is not on? Because nothing is using up the power so where could it go? I know a 400W is probably a overkill to power a PIII 666 computer, but I was hoping I could power something else if i needed it.
    Any help would be greatly appreciated.
    Ground the case of the computer to the car and it will help a little. Make suer eveything is grounded well, the ground wires are short, adn they ground in the same spot. I did this to cure the same problem, but now get a whine from an upgraded soundcard use for surround sound as opposed tosterio; sterio worked fine.
    As for the power, I've already left my inverter on for several hours wihtout any problem, and it's 400 watss too. It wire actually even is used to power a reverse IR camera and 5 inch monitor, which I leave on sometimes just for kicks. Just remember to keep cables for a jub just in case, but if the computer is off you should get away with it being on for a while.
    [------|-] 95% computer... is it ever really done?
    www.vehicross.info for all you VXer's
      Why would grounding the case help with the whining? I tried turning off the computer and the wining doesnt' stop so I'm thinking it comes from the inverter. The current inverter is wired up to the car battery neg terminal I think thats the most perfect ground u can find. I guess a better question is What Causes the Whining noise???
      I left my inverter and computer on for maybe 45 minutes (car off) and the inverter light turned from green to red (meaning battery is goina be out as said in manuel) but then again I have a stock battery that has been running for 3 yrs so.... I know there'll be a day when I forget to turn off the inverter and left the car. and I don't have a backup jump yet
        whining will either be from low voltage or too high temperature (more likely). Its idle consumption should be written somewhere on the box or manual...
        Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
        Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
        CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
        http://www.no1knows.com/galleries/
          The inverter produces AC power - Alternating Curent. Your cr runs DC - Your pc Runs DC. The Inverters 12v and the PC's case combine those grounds together via the PSU - This connection doesnt account for or ground to the car chassis very well. The process of "Inversion" produces a lot of noise, and Your car really has no "True" ground - Your tires are rubber, there is nowhere to sink that energy.
          Your alternator produces noise, and you have a good change of building up ground potential between the devices. (place a volt meter between two grounds - it should be 0, try one lead on the PC's PSU and the other on the car body ground, you will probably see 1 - 5v) That is noise, and that is bad. combining all grounds should help, but in the long long a DC - DC psu is far superior.
          Gizmo-
          Techonlogy on Wheels
          http://www.hjnetworks.com/car
            666 megahertz bad luck
              Your inverter manual should state the current usage with nothing connected. I use to use a 300watt inverter and I think the current usage was just under 1 amp with nothing connected.
                Most invertors have a fan, make sure yours is workin. Also make sure the wiring feeding the invertor is the proper size. It could be undervolting. The pc could also be drawing to much power, which would mean your drawing to much. Its most likely an alarm, now ya just have to figure out the problem.
                -Drew Taylor
                2000 Grand Am GT PC
                  ok guys...in terms of true ground and alternator causing noise and such...its not quite as simple as you guys are making it out to be...also, the 1-5V potential difference you measure is *not* noise assuming your measuring using the DC setting of the DMM....
                  you guys are correct in saying there is a potential difference between the two components but i believe u are incorrect in your summation of WHY this is an issue...
                  if i was setting up this system i would ground the inverter as close as possible to the ground point of the amplifiers or whatever equipment the computer output is connected to and be sure the inverter ground wire is as short as possible...if that doesnt work i have a few more easy things to try....
                  grounding to the battery is about the worst place to ground the inverter for this particular aopplication....
                  Kevin
                    Kevin
                    umm what is "DC setting of the DMM...."
                    I thought the battery would be the most effective ground because well, gound is ground right? so I took the liberity of using 4m of wire and connecting it from the battery to the back of the trunk.
                    so why would extending the ground wire make it a worse ground?
                    So to sum it up If i want this noise to be gone I'm just going to use a short ground wire? sounds simple enough, I'm going to try it tomorrow and I'll let you guys know how it goes
                    o can can you tell me what some of the other easy solutions are just for refrence?
                      here is what is happening in a nutshell.....lets start from how i think u have it wired....
                      inverter at battery....connected to computer somewhere in car...audio output to amplifier in trunk i suppose....
                      the metal in the car has non 0 impedance(resistance with a non zero phase angle) because nothing is perfect so the metal is going to "impede" the flow of electrons...many people think u have to run a ground wire to the neg post of the battery because thats where u get the best power but for audio this is usually not the case...actually in most installs its the *worst* place to connect the stereo ground....the body of the car is so large that the impedance is low so u can have large current flow no problem even if u ground an amp in the trunk...this is why even tho copper is a better conductor than steel u will actually have a lower impedance in the car's metal than a smallish piece of copper wire of the same length(say from the engine compartment to the trunk)...
                      u asked about setting the DMM to DC...DMM = digital multimeter, DC = direct current, AC = alternating current...this goes back to people WRONGLY thinking that audio amplifiers produce DC when they are clipping...this is completely incorrect if the amplifier is working properly...it produces a clipped AC signal, NOT DC, even tho it "looks" like a square wave...so what?
                      well in the car u WILL have a non zero voltage because the metal has a non zero impedance...according to Ohms law voltage = current * resistance...well u have currents flowing all over the chassis of the car...the metal has a non zero impedance so of course your gonna measure a voltage...if u didnt then either u have done something wrong or your meter is faulty...the point is that this 1-5V that was mentioned is not necessarily noise...if u measure it using the DC setting of the DMM i would wager it is NOT noise but just the voltage drop your gonna have..this is easy to show using a piece of wire in your bedroom connected to even a 1.5V AA battery...and we have no noise there(technically everything causes noise but we have to think relative here just like anything else...the amount of noise u have is nowhere near an issue at these levels)....
                      but here is the kicker....because of this non zero impedance in the chassis of the car, AC currents and high frequency DC(such as u will have with computers and DC/DC power supplies, the car's sparking system, etc) traverse all over the chassis...there will be quiet spots and loud spots(basically spots where u have more currents flowing than at others) and this is directly dependent on the electron flow pathways from the battery to where u mount your equipment...there is no way to know where these quiet spots are unless u test for them...this is something that most car audio installers dont even know which is sad really....
                      ok so now we get to why the batt is a bad place to connect equipment...first off ground is not ground as any PS designer will tell u, and its because of precisely what goes on above...the impedance of the "ground" makes the ground relative, even on earth where someone mentioned that u have "true" ground...this is also incorrect...when a building is designed for lightening protection etc. such as say a train servicing yard, there is a grid of steel built under the structure where the steel grid intersects usually at about 40ft to 80ft square to help ensure that the ground potential at one side of the building is very close to the potential at the other side of the building so that u dont have these currents flowing through the building...remember Ohms law, if resistance = 0 then current must equal zero as well....the battery terminal is the spot on the car where all the current is returned so it is by definition the noisest spot on the car u can connect a ground wire ....that and the fact that u can measure a voltage difference between the battery terminal and the ground spot of the amplifiers makes a perfect situation for noise to enter your system....
                      with your system u have a different ground potential for your audio outputs of the computer when compared to the ground of your amplifier(basically u could put a voltemeter on the ground of the audio output of the computer and then put the other end on the ground of the amplifier and u have a non zero voltage) and this is a bad situation for u *especially* because your probably not using a "true sine wave" inverter...you probably using a cheap chopped DC version like the mainstream Vectors...they make the inverters for nearly everybody..radio shack, husky, etc. etc...to help this u can add high voltage capacitors to the output of the inverter to help filtering the noise out of the signal but this is not for the beginner..u can also beef up the DC side of the computer's PS but again this is not for the beginner....
                      the audio outputs of *aftermarket* headunits in most cars are grounded and the ampifiers input RCA ground is usually lifted off of ground by using a resistor inside the amplfier...this is to avoid what is called "ground loops"(what your dealing with now is a ground loop) but it only works well when the amplfier and radio are at about equal ground potential and both are grounded to quiet spots..
                      this is why at times people mention that u should just move the ground wire when u have noise...u might hit a quiet spot on the chassis and the noise goes away..this is also why people mention isolators..u isolate the ground wire of the computer to the amplifier so u cant have a ground loop assuming the rest of the system is installed properly...a bandaid but it works in many sitations..it has disadvantages in sound quality tho so no hardcore audiophile worth his salt ever uses one of these...in OEM equipment where u have an OEM amplifier, the cars usually come with a +-0.5V balanced system...people always talk abot needing X output voltage on headunits to have no noise or to have great sound quality, blah blah blah...its mostly based on ignorance...aftermarket manufacturers could easily solve the problem(and some do!!!) by just making balanced audio cards(hint for u guys, using a pro audio card like the EMU by creative will solve your problem if u get a balanced receiver) that we can easily use in the car and mating it with something like a pheonix gold balanced receiver or better yet, make all amplfiers balanced.....this would allow all the "common mode" noise or noise flowing down BOTH wires to be cancelled so that u get just music and no noise...***EVER***....u wanna ensure u never have engine noise again? run balanced....
                      here is another myth...people talk about running signal wires and power wires down opposite sides of the car....no matter where signal wires are run they will be close to the chassis of the car which means they will be close to all those currents i spoke of earlier and these same currents are the ones that enter our system...i hope it now makes sense that where u run the signal wires inthe car makes little difference if u design and implement your install correctly....
                      from the above i hope it's evident that it's mostly trial and error for the average person and for those who know what they are testing for it can be a whole ton of work just to get a quiet system....
                      i hope i didnt bore u guys/gals too much....the above is the tip of the iceberg and i have a headache so i didnt wanna get too indepth....i also hope u have a slightly better understanding of what's going on with noise in the car.....
                      Kevin
                        WOW!!! I mean WOW tundra, I had no idea what i was getting into That is (to me) already a very indepth detail of why things are happpening and I think i'm beginning to see the light ! Too bad I didn't ahve a chance today to test it out cause I was busy during the day and its dark now.
                        How do you know all this? Are you somekind of an installer??
                        O and THANKS for all the info I'm actually going to save what you just said in a file
                          no problem...i hope it helps u have a quiet system....
                            Tundra, Excellent post. Should get it stickyed. I know quite a bit about this issue also, and it frustrates me when local shop fill peoples heads full of crap, basicly.
                            John
                              noise
                              i dont know that anyone answered your question about what noise is and where it comes from..........noise is distortion in a signal that carries no useful information...............there are two main types of noise additive which can be removed (not always easily) and multiplicative which cannot be removed.......the noise in this case is additive.............the reason people like to run signal wires and power wires on two opposite sides of the car are this: current excites a magnetic field which can in turn excite a current in a nearby wire...signal wires usually have small amounts of current until they reach the amp....therefore the magnetic field of these currents is small and unlikely to excite any current in a nearby wire.......power wires have a greater current and greater field strength making them more likely to excite noise in a nearby wire
                              im sure there is more to this but im just sharing what i can think of on the spot that might help
