opus somewhat powering on?
  • opus somewhat powering on?
    Hi, about a week ago i installed an opus to my carputer instead of an inverter and a psu. system specs:
    epia m10000
    512 mb ram
    200 gb seagate
    150 watt opus
    liliput 7" touchscreen
    I did not wire the opus to the ignition, instead i use a switch to turn the computer on/off. The opus has been working great up until yesterday. While driving, it seemed like the computer went into sleep mode. After a bit of driving, i wanted to listen to some music so i tapped the screen to get it out of sleep mode. The computer would not come back. I checked the LED on the power switch and it was solid. I turned the computer off, then back on, the LED would light up, which shows that its getting power, but the opus fan is not spinning and the opus is flashing 4 times.
    Has this ever happened to anyone? Could my opus have suddenly died on me?
    epia m10000
    512 mb ram
    200 gb seagate
    150 watt opus
    Well, did you wire it up correctly? and did you re-check all the connections?
    Laidback
    The ultimate CarPC - Wow!
      everything is wired correctly and all connections are good. I cant seem to figure out the problem. Still getting 4 flashes.
        Did you read the manual to see what 4 flashes means?
        Laidback
          this is the same problem as me. =(
