Mastero MK4.5 Parts list Question?
  • Mastero MK4.5 Parts list Question?
    Hello,
    Well i figured I might try my hand at this project however i'm having some trouble knowing exactly which parts to chose on digikey. Some of the parts have multiple versions and such and I am really not sure that i have put together a list with the right parts. This is what i have come up with....
    Index Quantity Part Number Description Customer Reference Backorder Quantity Unit Price
    USD Extended Price
    USD
    1 1 493-1297-ND CAP 10UF 25V ELECT VZ RADIAL 0 0.22000 $0.22
    2 10 399-1278-1-ND CAP .01UF 25V CERAMIC X7R 0402 0 0.05500 $0.55
    3 4 P10298-ND CAP 330UF 35V ELECT FC RADIAL 0 0.56000 $2.24
    4 7 493-1065-ND CAP 1000UF 25V ELECT VR RADIAL 0 0.58000 $4.06
    5 6 493-1304-ND CAP 470UF 25V ELECT VZ RADIAL 0 0.34000 $2.04
    6 1 493-1089-ND CAP 4700UF 35V ELECT VR RADIAL 0 1.87000 $1.87
    7 2 493-1564-ND CAP 2200UF 25V ELECT HE RADIAL 0 1.20000 $2.40
    8 2 P12383-ND CAP 220UF 25V ELECT FM RADIAL 0 0.32000 $0.64
    9 1 493-1041-ND CAP 220UF 16V ELECT VR RADIAL 0 0.30000 $0.30
    10 1 P5152-ND CAP 100UF 25V ALUM LYTIC RADIAL 0 0.23000 $0.23
    11 1 P12372-ND CAP 330UF 16V ELECT FM RADIAL 0 0.32000 $0.32
    12 1 493-1044-ND CAP 1000UF 16V ELECT VR RADIAL 0 0.57000 $0.57
    13 2 478-1835-ND CAP TANTALUM 1UF 35V 10% RAD 0 0.46000 $0.92
    14 5 2.7KH-ND RES 2.7K OHM 1/2W 5% CARBON FILM 0 0.04600 $0.23
    15 5 47KQBK-ND RES 47K OHM 1/4W 5% CARBON FILM 0 0.05600 $0.28
    16 5 470H-ND RES 470 OHM 1/2W 5% CARBON FILM 0 0.04600 $0.23
    17 5 33KQBK-ND RES 33K OHM 1/4W 5% CARBON FILM 0 0.05600 $0.28
    18 5 1.8KQBK-ND RES 1.8K OHM 1/4W 5% CARBON FILM 0 0.05600 $0.28
    19 5 3.3KQBK-ND RES 3.3K OHM 1/4W 5% CARBON FILM 0 0.05600 $0.28
    20 5 1.0KQBK-ND RES 1.0K OHM 1/4W 5% CARBON FILM 0 0.05600 $0.28
    21 5 10KQBK-ND RES 10K OHM 1/4W 5% CARBON FILM 0 0.05600 $0.28
    22 1 490-2646-1-ND TRIMPOT 1000K OHM 1 TRN 3MM SMD 0 0.80000 $0.80
    23 5 490-2030-1-ND POT 500K OHM 3MM TRIM 1TRN SMD 0 0.11000 $0.55
    24 1 490-2250-1-ND POT 200K OHM 3MM TRIM 1TRN SMD 0 0.75000 $0.75
    25 6 MBR745IR-ND DIODE SCHOTTKY 45V 7.5A TO-220AC 0 1.09000 $6.54
    26 4 1N4148FS-ND DIODE SGL JUNC 100V 4.0NS DO-35 0 0.07000 $0.28
    27 10 1N4007GICT-ND RECTIFIER 1 AMP 1000V DO-41 0 0.04000 $0.40
    28 2 1N914BCT-ND DIODE SS HI COND100V 200MA DO-35 0 0.10000 $0.20
    29 2 497-2395-ND TRANSISTOR NPN 60V 200MA TO-92 0 0.32000 $0.64
    30 1 497-2600-5-ND TRANSISTOR NPN 60V 4A SOT-32 0 1.13000 $1.13
    31 4 M1285-ND INDUCTOR TOROID 10UH 15% HORIZ 0 2.56000 $10.24
    32 6 M1289-ND INDUCTOR TOROID 47UH 15% HORIZ 0 2.66000 $15.96
    33 1 MC14049BCPOS-ND IC INVERTER HEX CMOS 16DIP 0 0.56000 $0.56
    34 1 296-12786-5-ND IC HEX INV SCHMITT TRIG 14-DIP 0 0.48000 $0.48
    35 1 MC7805CTFS-ND IC REG 5V 1A 4% TO-220 0 0.53000 $0.53
    36 1 LM7905CTFS-ND IC REG 1A -5V 4% 3 TERM TO-220 0 0.53000 $0.53
    37 1 LM7912CT-ND IC VOLT REG NEG 12V 1.5A TO-220 0 1.28000 $1.28
    38 6 A1921-ND CONN HEADER VERT 2POS .100 TIN 0 0.10000 $0.60
    39 1 160-1143-ND LED 3MM GREEN TRANSPARENT 0 0.19000 $0.19
    40 1 404-1112-ND LED RED CLEAR 3MM HIGH BRIGHT 0 0.50000 $0.50
    Subtotal $60.66
    My ideal situation would be to get a shipping manifest from someone that has bought all of there parts off of digikey so that i can just add all the parts i need to my shopping basket and check out.
    If there is any one kind enough to help me out on this board it would be greatly appreciated. I'm really new to this DIY electronics thing and would really like to try my hand at this project.
    Alot Tyler
    http://www.mazda3forums.com/Themes/f...tom/1_logo.jpg
    <img src="http://www.whereismygps.net/signature.php?use rname=Leddy&offset=-6"></img>
    Any part ending in ND is a digikey part number so take for example:
    1 1 493-1297-ND would be first part in list, one part needed, then the part number. I am affraid you will have to cut and past all those to order. I maybe wrong but that is the way it looks to me.
      Hey ,
      Thanks for he response but the reason the nd's are there is because i added all of these parts to my checkout basket then just pasted the checkout content into that message
      I'm not sure what your point was... ?
        I would like for the list also, if anyone have it.
          Ok here is a list
          Hello,
          I've been working on a list on farnell's website of what I think are the proper components for the mk4.5. If someone can verifiy that this list is in fact correct then I will go ahead and make a list for digikey as well.
            Actually i'm going to make up an excel file with web links to the products that i have included in the list i'll have it tommrow night
