inverter wiring question
  • inverter wiring question
    ok all here is a quick question on wiring inverters(i know not the best solution) I am plainign on using a 12awg wire with inline fuse to run the power to my inverter but my question is i want a switch int he front to turn the inverter on and off so what i am asing is do you all think i should cut the wire at the front of the car and put a switch in it or what is you guys suggestions
    You can get a shutdown controller for it from the mp3car.com shop
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
      as stupid as this sounds i would rather not use a shutdown controler right now that is why i am asking for thoughts
        I don't think it's stupid.
        Although I am curious as to why you wouldn't want the convenience.
        How about the Wiki?
          maybe you should consider what im doing....
          take the power antenna wire from your head unit and put it into a relay to power the inverter...so the carputer will be on as long as your stereo is powered up
          Current Progress:
          [▓▓▓▓▓▓▓---]80%
          Final Assembly
          Ramline P3 PC
          10.4 inch Touchscreen
          Windows XP Embedded
          Road Runner
          http://www.projektnepa.com
          Electrical Engineer / Mobile DJ
            OK just so we are talking on the same wavelength I didn't mean shutdown controller as in Opus,Carnetix etc - I understand you want an invertor, I meant shutdown controller for the invertor. You may have already understood what I meant, so if you did, smashing.
            The circuit above is a good idea... Also you could just hook up a switch/relay combination to give power to the invertor and of course to make sure that your not running all that juice through a switch, if that worries you.
              I have been running mine in this configuration (switch located under my dash on 12v line before it gets to the inverter and the inverter power switch left in the on position) for a couple of years now and have had no problems. I wired it up to my accessory line so even if I froget to turn off the inverter with the switch it will still shut off when I shut off the car. Unfortunatly this has lead me to power off the pc without shutting it down leading to a long boot the next trip. To solve this I broke down and ordered a shutdown controller...cant wait till it arrives.
              Hope this helps.
              1997 VW Jetta GLX VR6
              old HP MP
              PIII 600 or so 256 MB
              7" Xenarc
              and some plywood holding it all together
              My Project
                thanks for all the advice i just wasn't sure if i would run into any problems simply putting a switch in
                  yeah a switch is good and simple, but i think automated stuff is always better.
                  Current Progress:
                  [▓▓▓▓▓▓▓---]80%
                  Final Assembly
                  Ramline P3 PC
                  Windows XP Embedded
                  Road Runner
                    If they don't want it, they don't want it. There's no telling some people
                      i am all for automation but some stuff i like to do my self what can i say
                        uh well
                        Current Progress:
                        [▓▓▓▓▓▓▓---]80%
                        Final Assembly
                        Ramline P3 PC
                        Windows XP Embedded
                        Road Runner
