M1-ATX, dual selectable timing modes
  • M1-ATX, dual selectable timing modes
    Just a bit of info that might be useful...
    I want to use my M1-ATX normally in the 5s/2h mode. But the will be circumstances where I would want to leave the PC on a little longer to perform sync etc.
    So, to do this you can connect a switch onto the jumper section of the board. Have a jumper on B (5s/2h) and connect a switch to the 2 pins of C.
    Operating the switch before turning off the ignition, will override the timing into 30m/never mode.
    I have not tried this yet, but have confirmed it with Mini-box.
    HoSS
    I've thought about doing this. No reason why you couldn't.
      I know. It wasn't a question.
        In the last firmware version I saw, they were reading the dip switch settings continuously (in most cases) rather than caching them. So yah, it should work as they've confirmed.
        2004 4runner
