Constant 12volt feed
  • Constant 12volt feed
    I know that when the car is ticking over the system is running at 14.4volt and when the car cranks it drops a lot lower in voltage.
    Is it possible to find a constant 12volt electrical feed inside a car?
    Yes if you fit a Opus, Carnetix or similar PSU. That's the reason why people use them.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
      Ah no problem. I just thought there was a way around it because i have found some computer's which will run at 12volt DC.
        the Carnetix is the usual bit you need for a computer's that have a 12V DC-DC PSU built in.
