Can Shuttle SN41G2 be used without special Opus?
  • Can Shuttle SN41G2 be used without special Opus?
    Guys,
    After alot of research I am thinking of changing my planned setup (AGAIN!) from a Micro ATX setup to a Shuttle SN41G2 V3.
    http://www.microdirect.co.uk/Product...580&GroupID=87
    (Dual VGA, SATA, Firewire, SPDIF )
    I plan on using a Mobile Athlon - anyone know if the mutipliers/voltage can be adjusted in BIOS? Is the wire mod needed?
    I have already bought the Opus PSU but its not the special Opus you can buy for a Shuttle setup.
    Will it still work? Can it be adapted to fit into the Shuttle case?
    Lexputer Installed!
    http://www.mp3car.com/vbulletin/show...401#post522401
    That "special opus" is only a bare opus bord mounted on some fancy plate to be bolted in the Shuttle.
    You "non-special" opus will work. To fix it, well, maybe someone here have that special mounting and could put a little schematic with the most important dimensions of the thing.
    Now Galileo is real. Muhahahahaha :p
      Thanks DeltaFX!
      I have emailed the place I bought it from and asked if I can swap it, hopefully its ok to do so.
      Anyone know about the wire mod and the shuttle?
      Lexputer Installed!
        anees, did you get your shuttle/opus150 system up and running? did u have to do any mods to the mobo? thanks
        '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
          I have the same system.
          I used Matero's MK4.5 making a bracket to hold the supply and the HD. You have to mod the boost voltage a bit, but the supply never broke 109 deg F this weekend.
          One very happy Shuttle owner
          1981 VW Scirocco, 2L 16v turbo. EEEPC 1000 running Mega Squirt and music.
          Http://www.menloparkrandd.com/scirocco
            i dont think shuttles have multiplier adjustment in the bios.
