MP3Car Store Controller
  • MP3Car Store Controller
    http://www.mp3car.com/store/product_...6af5a15a481e5d
    Is anyone using this? Is there any reason it couldn't be used as a controller to an inverter - turning on/off an inverter and thus the PC PSU power?
    Fabricator
    does your inverter turn on and off like a computer?
    'cause mine has a toggle switch....and from what I read this just sends a pulse to the power button.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    I'M DEBT FREE!!
    I'm now a reasonably successful gunblogger.
      you could still use that though, just make it shutdown the computer via the softbutton, and just use a 40A auto relay to control the inverter. so when it turns off the power it turns off the 40A relay.
      肚子笑痛了
      S60 Install
        If you read the quick overview here, it states that in addition to switching on the PC it turns on a 12V circuit and is rated for 20 amps. Sounds ideal for inverter applications.
        Fabricator
          You beat me to the submit post button. I have a SFF Optiplex GX-150 with only a 150 Watt PSU I was hoping to skip the relay and safely assume it'll never draw 20 amps.
          Fabricator
            ehh, even though mine never went near 20 amps, the sparking from everytime the relay contacted took out my first 20A relay then I switched to 40A did not see another problem
            mine was a 100watt PSU with a 300watt APC inverter
            肚子笑痛了
            S60 Install
              Well I'm trying to make this one a budget <$500 system, and hoping to omit the external relay altogether since that controller 12V turn-on circuit alone is rated for 20 amps.
              Fabricator
                can't hurt to try it
                肚子笑痛了
                S60 Install
