Using a high farad cap to survive engine crank
  • Using a high farad cap to survive engine crank
    Question:
    Have any of you guys tried a high farad capacitor to help survive engine crank? I would think a large 1 Farad cap or something like that would work because it can hold an emormous amount of electricity - and caps with their very low ESR are designed for "Deep Cycling" which those regulation circuit/engine crank devices with those APC style backUPS style batteries really aren't (regular lead acid isn't designed for deep quick dischage, though I am sure it works fine).
    Though a 1 farad cap probably costs more than an engine crank survivor thing + a lead acid APC style battery. Might have a problem though because you have to hook up inline, though I'm sure you could just hook up the ring terminals from the battery supply and the lead acid "engine crank" battery to the same leads on the invertor.
    -LAKORAI
    The engine cranking item is called a "crank Tank" I believe. www.thecarpcstore.com has it. Wonder if it works good - sure is a hell of allot cheaper than buying an OPUS. I don't really care that much about having a shutdown controller - though I am going to put a button on my dash - that's a NC (normally closed) push button right?
    -LAKORAI
      euh.. it should be a NO Button (normaly open)
        i have a 50farad cap for my system, i should try that out
          Originally posted by lakorai
          Question:
          -LAKORAI
          If you do some search on this power forum, then you will know why this isn't the one of the flavor for surviving engine cranking.
          Y2K Accord Dell GX150
          EmoRebellion is a SCAMMER
            What? another 1 farad capacitor thread? are you serious here? Where did you get all this idea?
            Are you aware that your 1 farad capacitor will only last about half a seconds when supplying 5A before your PC crash? hardly any time for cranking is it?
            Read here >>>
            http://www.mp3car.com/vbulletin/showthread.php?t=20226
            How about using 10 x 1 farad capacitor? That will cost you half of your car PC
            Anyhow theres only one way to find out, just go for it. Look like you already done your research.
            And please dont forget to write up a report on your finding and post it here.
            Thank you
              I was thinking the exact same thing.
              lakorai ... the short answer is no.
              If you want to survive a crank you either need to build a tank circuit or buy a power supply that is built so it can survive a crank (i.e. carnetix)
              My JeepPC Install
              "there are no stupid questions, just stupid people."
              "it's been agreed the whole world stinks so no one's taking showers anymore"
