Question On Opus 150Watt
  • Question On Opus 150Watt
    I am ordering an Opus 150 watt power supply. So two questions...
    1. Does this have the ability to do a delay power on for my amps so I don't have the amp thump problem. I know the M1 power supply does.
    2. Will I also be able to power my Audigy 2nx and a four port usb hub from this power supply?
    I have read many posts on the opus, but frankly the wiring part is where I really lack. So I knid of need a step by step On how to do these first two steps, includind wire gauges to be used.
    until you find a better answer
    my understanding is you will not be able to hook your amp up, how powerful is the amp?
    and yes u can hook up your usb hub since the opus has 5v connections. you will have to splice wires tho.
    Im not smart but i give you what i am learning through reading this site
    Go on and do it, do it, Do it 'til you're satisfied,
    Whatever it is, do it, Do it 'til you're satisfied.
    CarPc progress |OOOOXCOOOO| 57%
