What size fuse for 12v and 5v line on Opus
  • What size fuse for 12v and 5v line on Opus
    Hello All,
    Should I put a fuse on both the 12v and 5v line from the molex connector of the opus (in the trunk) to the front of the car for powering accessories like GPS, Audigy NX, USB hub etc.
    Should the fuses be as close to the Opus as possible or the other end near the accessories?
    What amperage do you recommend for the fuses?
    Sound Stage
    Eclipse|MTX|Infinity
    For more protection I'd say yes. I have three on the screens, located close to the Opus. The fuses for the screen are 1A each.
    Renault Megane...the OEM look
      Sorry I have little electronics skills
      So use a fuse for every device? or one fuse for each 12v and 5v line?
      so: 1amp fuse for lilliput on lilliput power line Y connector to 12v
      1 amp fuse for Audigy NX - power line Y connector to 5v
      1 amp fuse for 4 port usb hub - power line Y connector to 5v
      ** these are in my glove box up front so would be far from Opus
      or
      5 amp fuse on 5v line
      5 amp fuse on 12v line
      ** Opus is in trunk so fuses are close to Opus
      Sound Stage
        Are you trying to give more insurance to the Opus or the components that it is powering?
        VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
          Both would be nice
          Fuse them all?
          Sound Stage
            Originally posted by -zip-
            Both would be nice
            Fuse them all?
            Everything powered by the Opus (3 screens, DVD, USB hub, except for the neons), are fused. Just to keep me on the safe side.
              What kind of fuses are you guys using? I'm heading to Radio Shack later so I'm curious if there's some kind of specific fuse that works best.
                radioshack sells inline fuse holders. There by far the easiest to use.
                It's like a little tube with wires out of the end./ You open the tube up, pop the fuse in and close it. Voila! In-line fuse.
                  Another way is to go to a junkyard and rip a fuse panel out of a wrecked car and run your lines through that
                  oh, and you need to check your power ratings on what you're powering to know what size fuse to use (we have no idea). This and related issues have been discussed many times.
                  Da_Kooz
