For Inverter Users..Help Please!
  • For Inverter Users..Help Please!
    Could any of you using an inverter post some pics showing location of your pc, inverter, and startup controller?
    Thanks much!
    Micro ATX
    P4 2.8 ghz
    200 watt power supply
    ATI 9800 pro
    Haupauge 250 tv and radio tuner
    250 gig hard drive
    1 gig ram
    Alpine 4 channel amp
    Kicker 2 channel amp
    400 watt inverter
    2 10' Kicker subs
    Windows Media Center Front End
    Iguidance GPS
    Dont have pics now but the inverter is under the drivers seat (grounded to the seat anchor). Computer is on a custom built rack in the trunk and the SDC is mounted on there too. I dont have a case for my mobo currently
    Live mp3Car Facebook Chat
      reason
      was there a reason you decided to place the inveter under the seat and hot mount it in the trunk with the pc?
      Micro ATX
      P4 2.8 ghz
      ATI 9800 pro
      250 gig hard drive
      1 gig ram
      400 watt inverter
      2 10' Kicker subs
      Iguidance GPS
        because i like being able to hotswap my external dvd, hard drive etc in the cabin withot needed to go thru the trunk. i have a 4 port usb hub in my dash so it makes it quick n simple. Also, if the computer should crash or need to be immediately shut down i can just flip the switch on the inverter rather than pulling over etc.
          Our shutdown controller lets you remotely shutdown, or even force off, the PC if it was to lock up. See the Accessory Manual on our website.
          KyferEz
          TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
          PSU Wattage Calculator
          Electronics Calculators
          Copper Wire Data
