Optima redtop battery
  • Optima redtop battery
    Its power related...
    I have a chance to pick up a Optima redtop battery model 75/25. Here a link to the specs...
    http://www.optimabatteries.com/publi...cal_specs.html
    Its noted as a 'starting' battery, not a deep-cycle battery (just found out the yellow tops are the deep-cycle ones). Would this be beneficial to a under 150W carPC and 500-800W sound system?
    FYI, I'm buying a used alternator from a better equiped version of my car. It puts out 90A compared to 80A in the base model.
    My first carPC!
    MP3/CD player
    Celeron 633MHz - 10GB Seagate - 64MB PC100 - Win XP
    Soon to actually find its way into the car!
    If I understand you correctly, you just want to know whether it makes sense to put a red top in you car with that stuff in it? Yeah, it does, but you'd be better off with the yellow top. It will be fine when you are running the car, but its not going to last much longer than a standard battery with the ignition off.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
      Take it from someone who works for a battery distributor, and who charges/checks batteries including optima batteries. Don't use a redtop in your car. We have now refused to sell the red top optimas to car audio shops because of people who are too cheap to buy the yellow top and instead get the red top, and then expect warranty for the battery when it stops working properly. If you will be draining your battery, go deep cycle.
      My 1967 Mustang
      CarPC in progress
        Yellow Top all the way.
        Dont
        make
        me
        say
        it
        Noob.
        (All done)
        iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
          Get both. Ive got a red top starter battery with a fully isolated yellow top for the system. It works great. If your gonna do a carputer, you cant cheap out or you will regret it later when things dont work the way you intended.
          2.4 celeron
          150 watt OPUS
          micro atx
          xp pro
          tv/radio tuner card
          audigy
          Dual monitor Radeon
          802.11G Mimo
          xm pcr
          dvd
          gps
          8" Lilliput touch screen
          IGuidance
          dual optimas
          battery isolator
          15" screen
          My Truck
            Lol yeah thats the ticket. DO IT.
            Id wait till yer stock battery bit it before you exchange for a redtop, no point if yer batt still works.
            (All done)
              True that. Mine was all squished up and laying sideways from the accident. Then sat that way for about a year so I think its save to say that it was toast.
              2.4 celeron
              150 watt OPUS
              micro atx
              xp pro
              tv/radio tuner card
              audigy
              Dual monitor Radeon
              802.11G Mimo
              xm pcr
              dvd
              gps
              IGuidance
              dual optimas
              battery isolator
              15" screen
              My Truck
                Thanks guys. Stock battery is still going strong. I'll wait until I can buy a yellow top.
                As yes, I'm a noob
                My first carPC!
                MP3/CD player
                  Thats ok I play Warcraft 3 since it started like 3 i think years ago and im ranked 65 or so in the 1v1 ranking and yet i still get called a noob even when you win and win very easily and embarassingly for them. I mean i say to em, but you lost to me, who you call a noob, what does that make you?
                  I think the problem, for WC3 at least, is playing 12yr olds u have to expect immaturity.
                  (All done)
