Power cable to M1-ATX
  • Power cable to M1-ATX
    How did you guys hook up the power cable to your m1? I plan on running 8 guage to it, but cant seem to find a spade terminal that accepts 8 guage that will fit onto the board.
    i have 4 guage going to my amp and then 12 from the amp to the m1.
    System: AMD Duron 1200+ , 512 MB ram , usb sb mp3+ , Tview 7" touchscreen , M1-ATX PSU , Slot Load iMac DVD-Rom , 40 GB laptop HDD, netgear USB 802.11g
    Progress: Installation: 90% Dash fabrication: 80%
    Parts Needed: USB GPS
      I ran 10 guage direct to my battery. The 10awg worked/fit fine for me.
      Mobo= Epia V
      Ram= 640mb
      Ps= m1-atx
      Screen= Lilly 7" ts
      Hd= 40gig
      case= 1/10 scale model of my car (04 Saturn Ion QC)
      soundcard= soundblaster mp3+
      GPS= Holux gm-210
        hmm...ill have to go back to home depot to take a second look at the spade terminals tomorrow. 10 guage should be ok...the 18 guage that it came with looked a little thin.
          i'm using 8 gauge wire and also had trouble finding a spade terminal. I bought a 10 gauge one it it fits just fine for the 8g wire.
            I'm using the 18 or some 16 and its working fine.
            Another Novice?
            Progress so far <-------*-> 88%
            Kenwood MPV5025 with Aux
            Via MII10000
            512MB Ram
            LG Slim DVD\CDRW
            Xenarc 700TS
            M1ATX
            Pharos GPS
            SYBA USB2.0 4-port Hub
            Bufalo 54Mbs Wirelessb/g PCMCIA card
              Yup 10G spade/ring.... connectors fit fine with 8G wire.
              Y2K Accord Dell GX150
              EmoRebellion is a SCAMMER
                The most the M1-ATX will possibly ever pull is less than 10A
                So just look for some cable that will do 10A
                I just used those screw terminal blocks to join the cable together or you could buy a set of spade connectors to connect both sets of wires together.
                System:
                256Mb, PIII 533 on a Hyph01 PCI sized mobo (Lan/Sound/GFX)
                M1-ATX PSU
                250GB Hdd
                USB:
                Haicom GPS
                Belkin Wireless
                Case:
                Installed in an old NTL box, (best thing for it)
                Screen:
                LinITX 7"
                  Connect the 8 Gauge to the cable that comes with the M1-ATX.
                  : Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
                  : Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
                  : BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
                    Thats what I was trying to say in my roundabout way
                    System:
                    M1-ATX PSU
                    250GB Hdd
                    USB:
                    Haicom GPS
                    Belkin Wireless
                    Case:
                    Screen:
                    LinITX 7"
                      wouldn't that defeat the purpose of running an 8G wire?
                        Depends...if there's a long distance to run between the M1-ATX and the battery, the larger the wire, the less voltage drop there will be across that distance.
                        System status: in progress
                          I just used what they gave with it then connected 12 gu to that
                          1990 Jeep Cherokee
                          2000 VW Golf TDI 4dr
                          2005 VW GTI MKIV - SOLD
