Opus power switch cable too short
  • Opus power switch cable too short
    Has anyone run into the problem of the power switch cable being too short (the green/white cable that runs from your Opus PS to your motherboard power pins)? I tried removing the wire from the pins in the white connector, and it's just impossible to connect a new wire since it's crimped so right.
    I am now looking at using a CD-rom audio cable to replace it since they are usually longer, but I was surprised to find out how short they are.
    I just mounted the Opus with the distance the wire would allow.
    I would just just cable wire in half and splice in some wire to give you the length you require?
