would this blow my fuse quickly?
  • would this blow my fuse quickly?
    i will have 2 amps in my system, totaling 100amps draw. if i used a 100amp fuse to power the amps, plus the opus and my dsp unit (3amp), would that blow right away? problem is, there is no 125amp or similar ANL fuse- if it would cause a problem, i'd have to run a 2nd 12v line to the trunk just for the carputer/dsp.
    probably not......i've got an amp that was supposadly pulling 65 amps, had it fused with a 50 and had my opus on there there too....worked fine
    PC Components:
    My work log
      It wont blow right away but why not use an anl fuse?
      http://www.partsexpress.com/pe/pshow...number=263-134
      http://www.partsexpress.com/pe/showd...number=263-142
      2.4 celeron
      150 watt OPUS
      micro atx
      xp pro
      tv/radio tuner card
      audigy
      Dual monitor Radeon
      802.11G Mimo
      xm pcr
      dvd
      gps
      8" Lilliput touch screen
      IGuidance
      dual optimas
      battery isolator
      15" screen
      My Truck
        100 Amps at 12 Volts = 1.2 KW of power. I doubt that you'll ever really pull that much juice, even on the loudest of bass booms. The voice coil in your speakers are not wound with #4 cable. I think most car audio amps are spec'd based on what they theoretically can deliver, and not on actual load testing. Just my opinion.
        Walt
        Walts DC DC ATX Power Supply
