M1-ATX power shutdown failure
  • M1-ATX power shutdown failure
    Does or has anyone had a problem shutting down their system where it would restart again after? While using the M1-ATX?
    My 2000 Accord Project
    Are you issuing a shutdown command before you switch off the ignition?
    System status: in progress
      M1-ATX misbehavior
      Yes, in some situations I cant use shutdown because it will restart the system.
      When I suspend/hibernate, the 12v rail becomes 5v and the 5v drops to 0v.
      This issue almost damaged my lilliput!
      If 5v is supplied for a long time it will destroy my display.
      I've heard about an updated firmware. Maybe it solves the problem, but it did not arrive yet.
      Do you know if your M1 is going to 5v in the 12v rail too?
        just purchased M1, it worked few times then gave me the shutdown problem, 5v on the 12v, I really hope it can be fixed
        Peugeot 206 1.4 HDi
        Intel Mini-ITX Mainboard
        Celeron 1.2ghz
        256mb DDR-2 533
        80gig 3.5" SATA HDD
        Sb Live 5.1 w/ KXProject Drivers
        M2-ATX
        8" Lilliput TS LCD
        100% installed and working :D
          Do you have the latest firmware?
            well I purchased it a week ago, I hope to have it
            is there a way to verify? if it is not the latest I have to find out a pic programmer somewhere..
            Peugeot 206 1.4 HDi
            Celeron 1.2ghz
            256mb DDR-2 533
            80gig 3.5" SATA HDD
            M2-ATX
            8" Lilliput TS LCD
              I took a pic from a working M1 and put to mine, the problem remain so it is not a firmware-related problem
              mini-box.com says to ask a RMA
              Peugeot 206 1.4 HDi
              Celeron 1.2ghz
              256mb DDR-2 533
              80gig 3.5" SATA HDD
              M2-ATX
              8" Lilliput TS LCD
