xbox power supply
  • xbox power supply
    I want to put my xbox in my car without using an inverter.
    From what Iíve found by searching, this is what I need:
    ATX DC-DC PSU-What kind do I need (links to some options would be good)?
    Power converter-this thing
    Will this set-up work?
    Will the power supply be able to power the DVD and hard drive of the xbox as well as an lcd screen?
    Does the power supply connect directly to the battery?
    I have no clue about this stuff so any help would be greatly appreciated
    Yes.
    I'd think an Opus 150 would be able to handle all of that. I think it's been tested by someone here, even. Search the forum.
    Yes.
    How about the Wiki?
      It should, the xbox uses 100 watts, so then you have 50 watts to spare assuming you get an opus 150.
        So you can get an Opus 120
        PowerVoice v1 | NaviVoice Source
        GammaControl v2.4
        SKINbedder v3
        1995 Lexus SC300
